V6 oil pressure gauge.
windywatson
Post by windywatson » Wed Sep 07, 2016 1:50 pm
Hi All,
Thinking of installing an oil pressure gauge to both my V6 petrols as they are getting older & having a gauge would give valuable information as to the performance of the oil pump & ultimately prevent any engine damage should the pressure start to become an issue.
Anyone fitted an oil pressure gauge to their van? If so could you tell me what thread the sensor is so that I can get a T piece to fit for the pressure take off. I intend to still leave the standard warning light so will be retaining the pressure switch as well. I assume the oil pressure sensor is somewhere in the area of the oil filter.
Any advise welcome.
Windy-Watson
2001 V6 Tin Top
Re: V6 oil pressure gauge.
Post by Northern Bongolow » Wed Sep 07, 2016 8:06 pm
18-501 is the pressure switch. fitted as you suspected above the filter mate.
http://lushprojects.com/bongopartsmk2/c ... no=.html#4
