help - lost ring down windscreen air vent
swat
Post by swat » Fri Sep 02, 2016 10:47 am
Arrgh, we've lost a ring down the drivers side inside windscreen air vent - it slid down the dashboard top and just fell in. It has big sentimental value! Where is it likely to have ended up? What's the easiest way to get into the vent to look for it?
Any suggestions greatly appreciated...
Steve
Re: help - lost ring down windscreen air vent
Post by Bob » Fri Sep 02, 2016 11:33 am
First thing to try might be the Hoover.
Put old tights/thin cloth over pipe, seal as best you can, inc other vents, and give it a go.
Otherwise its follow trunking.
Good luck.
Post by g8dhe » Fri Sep 02, 2016 11:53 am
Most likely in the windscreen vents pipe running long the base of the window shown below;
Post by Bob » Fri Sep 02, 2016 12:14 pm
Well done , Geoff. :)
If you can access it worth trying the Hoover method from below.
swat
Post by swat » Fri Sep 02, 2016 1:39 pm
That's great guys, thanks for the advice and the picture! I'm glad the pipes look mostly horizontal, will try and get in there tonight...
Post by Northern Bongolow » Fri Sep 02, 2016 8:34 pm
if you open the drivers door and look at the end of the dash, there is a roughly triangular shaped panel this removes, it should help you.
64-911b on this link.
swat
Post by swat » Mon Sep 05, 2016 10:46 am
Thanks again for the help. We got it out ! We realised that with some sharp braking the ring slid to the front of the vent and could be seen by someone sitting on the bonnet - after a couple of frustrating hours fishing with a bent piece of wire, eventually sticking a load of duct tape to the end did the trick! Big sighs of relief all round :-)
Post by Bob » Mon Sep 05, 2016 12:31 pm
Well done. =D>
Bongoplod
Post by Bongoplod » Tue Sep 06, 2016 1:05 am
swat wrote:Thanks again for the help. We got it out ! We realised that with some sharp braking the ring slid to the front of the vent and could be seen by someone sitting on the bonnet - after a couple of frustrating hours fishing with a bent piece of wire, eventually sticking a load of duct tape to the end did the trick! Big sighs of relief all round :-)
Well done,and a big up to the person who was shitting on the bonnet while you did some sharp braking....ooops ,sorry,misspelled sitting :shock:
swat
Post by swat » Wed Sep 07, 2016 7:46 am
:lol:
TheStinkyHippy
Post by TheStinkyHippy » Wed Sep 07, 2016 11:50 am
Must have been scary, several hours of laying on the bonnet while someone drives fast and suddenly brakes.
Glad you got it back.
