which coolant do i need?
Whatersname
Post by Whatersname » Sun Aug 21, 2016 7:57 pm
Sorry full of questions tonight. Picked up bongo on Fri. Just checked the coolant level and it's half way between Mac and low. No coolant alarm installed yet... 3 weeks time. The chap we bought it off of had a bottle but hadn't used it as it was a different colour to what was in the tank already. The bottle was halfords OAT antifreeze and coolant, is this the right stuff, it's pink. Thanks in advance
Gasy
Re: which coolant do i need?
Post by Gasy » Sun Aug 21, 2016 9:43 pm
If it's a different colour
I woundt use it
Just top it up with water if it's just a little bit
General rule is use the same colour as what's in it already
You can get the strength of existing coolant tested
Loads recomend a flush of all the coolant and new anti freeze every 2-3 years
If it's going in to the garage soon just top it up with water and ask if they can test it
Whatersname
Post by Whatersname » Sun Aug 21, 2016 10:34 pm
It's half way. I will be keeping an eye on it over the next few weeks and in 3 weeks it's going in for a service so I can get it changed/ topped up then.
Whatersname
Post by Whatersname » Sun Aug 21, 2016 10:35 pm
Sorry.... Thanks
Post by Bob » Sun Aug 21, 2016 11:14 pm
Worth having it changed.
The corosion inhibitor runs out of oomph over time, alloy head with iron block is galvanic corrosion in a can.
Post by mikeonb4c » Mon Aug 22, 2016 8:24 am
Bob wrote:Worth having it changed.
Agree with Bob. Ask Allans when they're back off hols. And i'd fit a low coolant alarm as much better than having to check.
Yan
Post by Yan » Mon Oct 24, 2016 12:47 pm
Just thought I'd ask in this thread rather than starting a new one.
I've had the same thing, bought a van and the guy gave me the RED OAT coolant, but the tank has green in it. I'm not going to mix them!
Does any know if G48 coolant is OK to use in a Bongo (2ltr Petrol)?
Thanks!
cmm303
Post by cmm303 » Mon Oct 24, 2016 5:29 pm
Yan wrote:Just thought I'd ask in this thread rather than starting a new one.
Thanks!
Same coolant for all bongos
This post goes into coolant specs: http://igmaynard.co.uk/bongo/forum/view ... 30#p680714
Chris with BertieB
Yan
Post by Yan » Mon Oct 24, 2016 11:45 pm
Thanks cmm303.
I must be missing something as I can't find G12+ (as described in that post) anywhere? where does everyone buy their coolant from? as I say it's a green looking coolant that's in it now.
Gasy
Post by Gasy » Tue Oct 25, 2016 6:51 am
Think the best option if you don't know what's in it is
Top up with water, untill you can drain and flush completely
And fill and bleed with new coolant suitably for a engine with steel and aluminium
Halfords or any auto shop
Think you need 6 or 7 litres of coolant most use the red one
Post by haydn callow » Tue Oct 25, 2016 9:05 am
Whatersname wrote:It's half way. I will be keeping an eye on it over the next few weeks and in 3 weeks it's going in for a service so I can get it changed/ topped up then.
Make sure the garage knows how to bleed the cooling system after changing the coolant.......if any doubt go to someone who does.....get it wrong and big bills are the result.
See the YouTube vids ' search 'bleeding bongos'
Yan
Post by Yan » Tue Oct 25, 2016 9:33 am
Gasy wrote:Think the best option if you don't know what's in it is
Thanks Gasy. I think you're right, as I don't know what's in there I should look at flush and replace. As Haydn has suggested, I think this might be best left to a bongo friendly garage.
Might be handy if everyone lists what coolant they use so we can see which is the most popular choice.
Post by haydn callow » Tue Oct 25, 2016 9:41 am
If you change to red oat coolant I would suggest you leave it 2/3 weeks before fitting the low coolant alarm LCA. RED coolant of tens coats the inside of the system with a protective layer. This also coats the LCA sensor screw and can cause false alarms. After a couple of weeks it will stop doing this and all will be fine....alternatively you can clean the sensor screw when it false alarms.
