No engine coolant bleed pipe
Posted: Wed Aug 17, 2016 5:51 pm
by Hoggins
Hi All,
Very recently joined the Bongo club, and so far loving the motor - however when checking for the bleedpipe under the passenger seat, it just isn't there! Turns out, when the head was replaced (I assume), the wrong tee piece was used, ie a ford ranger tee was used, with only two outlets, and no bleed outlet.
I've read a partial response on the old bongo forum regarding adding a tee to the Turbo coolant pipe to use for bleeding - has anyone done this, and if so, has it worked well? Are there guides to doing so (I cant find any!).
Cheers in advance,
Hoggins
Re: No engine coolant bleed pipe
Posted: Wed Aug 17, 2016 6:55 pm
by Northern Bongolow
try this mate.
or type in the search, t piece and turbo and a few links come up.
http://igmaynard.co.uk/bongo/forum/view ... turbo+pipe
Posted: Wed Aug 17, 2016 9:38 pm
by Hoggins
Absolutely perfect, many many thanks - looks like I have a project! :-)
