Hi All,
Very recently joined the Bongo club, and so far loving the motor - however when checking for the bleedpipe under the passenger seat, it just isn't there! Turns out, when the head was replaced (I assume), the wrong tee piece was used, ie a ford ranger tee was used, with only two outlets, and no bleed outlet.
I've read a partial response on the old bongo forum regarding adding a tee to the Turbo coolant pipe to use for bleeding - has anyone done this, and if so, has it worked well? Are there guides to doing so (I cant find any!).
Cheers in advance,
Hoggins
No engine coolant bleed pipe
Re: No engine coolant bleed pipe
try this mate.
or type in the search, t piece and turbo and a few links come up.
http://igmaynard.co.uk/bongo/forum/view ... turbo+pipe
Absolutely perfect, many many thanks - looks like I have a project!
