Spare wheel
sjm
Spare wheel
Post by sjm » Tue Aug 09, 2016 9:27 pm
I'm a new Bongo owner and have already learnt a lot from the forum.
I am trying to replace my space saver spare wheel with something more substantial but its proving trickier than I hoped.
This is complicated slightly by the fact that I bought my Bongo from a dealer who had put aftermarket alloys on it (which look smart!) but which are 255/45/R18 in size.
From searching on the web it appears that the Bongo originally came with this spec of wheels:
15 inch x 6.0. Offset 40. Bolt pattern – 5 x 114.3
Bore – 67.1
Further searching has led me to the conclusion (rightly or wrongly?!) that the following spec wheel would act as a more substantial spare:
Alcar KFZ 6655 - 6,50J x 16, 5 x 114.3, offset 42.5, central bore 67
http://www.oponeo.co.uk/steel-wheel/alc ... 5#19283146
assuming that I put a 235/60 R16 tyre on it - this seems to match very closely with the circumference of my existing wheels.
However when I ordered such a wheel online the supplier asked me what vehicle it was for - and when I said a Bongo Campervan they said they had no wheels homologated for my vehicle. They will supply me with the wheel but only if I send them an email absolving them of responsibility if it doesn't fit properly. Now I am unsure how to proceed, but remain keen to get a better spare wheel solution than the existing space saver.
Any advice on whether my proposed solution would work or not would be greatly appreciated.
thanks
Stephen
Re: Spare wheel
Post by Bob » Tue Aug 09, 2016 9:37 pm
Welcome aboard.
Consider a 15" original steel wheel as a spare.
Just check the rolling circuferance is the same the ones you have fitted, but this is far less important if yours is 2WD. :)
sjm
Re: Spare wheel
Post by sjm » Wed Aug 10, 2016 7:51 pm
Thanks,
I had considered trying to source an original wheel - but just thought buying a new steel wheel online would be simpler / quicker.
Thanks again
stephen
Re: Spare wheel
Post by Bob » Wed Aug 10, 2016 8:39 pm
There's a set of 4 going for £50 in the Small Ads, or ask on Stuff Wanted.
Otherwise breakers like Bongospares. :wink:
