Rust treatment Whats the best.
windywatson
Post by windywatson » Thu Aug 04, 2016 5:22 pm
A question for members with some body work experiance.
Unfortunatly the rear wheel arches are starting to rust. I know that in time I may have to have the full works done getting replaced etc. In the mean time I intend to treat the rust, fill & repaint the arches & as the rust has not progressed beyond a small margin I shall be using trims to cover the area of the repair as I'm sure I wont be able to get the finish good enough for it not to be noticable.
My question is this, what is the best type of rust converter product to use on any rust left after rubbing down the arches to metalwork? Once treated I will fill any small holes etc with body filler & then undercoat & paint. Would like to have the confidance that it could be kept at bay for a couple of years. I have found that the water has got into the edges of the arches through areas where the inner arch is spot welded to the outer & the gap has opened and water has been drawn in. What would be good to use as a sealant in these areas before painting?
look foward to your advise.
Windy-Watson
2001 V6 Tin Top
Re: Rust treatment Whats the best.
Post by haydn callow » Thu Aug 04, 2016 7:49 pm
Search FERTAN RUST TREATMENT on eBay. It's good stuff!
Post by haydn callow » Thu Aug 04, 2016 7:52 pm
I would be tempted to inject a good quality silicone sealant between the spot welds or a 'gum mastic'
Post by Northern Bongolow » Thu Aug 04, 2016 8:47 pm
this is the best one ive found. it works by isolating from the air by leaving a sort of plastic coating, this is paintable with or without primer, or simply left.
http://www.ebay.co.uk/itm/VACTAN-RUST-C ... 1025597300.
for seam sealing, there are purpose made sealers, see this link.
http://www.mig-welding.co.uk/seam-sealing.htm
Alan2016
Post by Alan2016 » Fri Aug 05, 2016 6:59 am
Is this the sort of thing I should paint inside new arches then or an I better to spray waxoyl in?
Bongolia
Post by Bongolia » Fri Aug 05, 2016 10:13 am
You neeed to get some form of rust killer in between the metal on those arches b4 sealing. I believe there is some called
Furtan? (I think) that comes in aerosol form with a tiny pipe , like wd40 has. Use this first and beneath any holes exposed when grinding off.Rather than body filler use a chopped mat fibre glass first and waterproof filler after.
I am bongoing in Kent at the moment but will do a "cold repair" post when I get back if that helps.
the1andonly
Post by the1andonly » Fri Aug 05, 2016 3:53 pm
another endorsement for Fertan readily available from Chandlers (boat shops) used by narrow boat people.
www.fertan.co.uk
Alan2016
Post by Alan2016 » Fri Aug 05, 2016 9:10 pm
Bongolia wrote:I am bongoing in Kent at the moment but will do a "cold repair" post when I get back if that helps.
That sounds great. My needs might be a bit simpler than the OP though. My arches were replaced by the dealer just before I collected the bongo. They don't seem to have the spot welded open seam underneath but just a single edge. I have read that it is a good idea to remove the read cup holders or entire panel and squirt in waxoyl from the inside. I'd certainly be interested to know if there are better alternatives or anything else I can do in addition to waxoyl to extend their lives as much as possible.
Post by mikeonb4c » Fri Aug 05, 2016 10:36 pm
This is working pretty well for me:
http://igmaynard.co.uk/bongo/forum/view ... glass+arch
the1andonly
Post by the1andonly » Fri Aug 05, 2016 11:28 pm
When using waxoil, waxoyl on wheel arches dilute with 20% white spirit easier to spray and penetrate (will come out of seams) It will stink for months.
Thriller
Post by Thriller » Tue Sep 20, 2016 2:20 pm
If using Fertan is there any preparation work required?
Or is it simply a case of spray/rub on to affected area, leave 24hrs, then re-paint?
Will it taint non affected areas?
Bongolia
Post by Bongolia » Tue Sep 20, 2016 6:07 pm
i am giving Furtan tech a ring on Wednesday so I will post what he says.
Thriller
Post by Thriller » Tue Sep 20, 2016 6:18 pm
Bongolia wrote:i am giving Furtan tech a ring on Wednesday so I will post what he says.
Excellent, thanks!
Bongolia
Post by Bongolia » Wed Sep 21, 2016 3:32 pm
Spoke to Fertan guy today.
If you are using it in a blind situation like inside of a box section then there is no need to wash it off. Inject your waxes on top after leaving it for 24 hours was his recommendation.
If on an external panel then remove the worst of the rust and then wet it ,apply the fertan. leave it 24 hours then wipe over with a damp cloth to remove the dust? Then it can be painted over directly.
As to its affect on surrounding paintwork, it would seem to be dependent on coating/ type of paint used. So I would say better safe than sorry you try it in an area that would be inconspicuous like a door shut first.
Alan2016
Post by Alan2016 » Wed Sep 21, 2016 5:04 pm
So the procedure for an interior panel would be to expose the panel, coat with Fertan, wait a day then spray with waxoyl or dinitrol? Would this be the same with the stuff you link to Northern Bongolow or wouldn't that then need the waxoyl?
Alan
