Coolant alarm(s) help
Ahead
Post by Ahead » Fri Jul 29, 2016 6:10 am
2 issues you might be able to help, easier first
Haydn alarm: in putting right damage caused by someone trying to steal the Bingo, I've pulled a wire free so alarm no longer working It's the red/black of the paired wire. Not sure if this goes to earth or ign switched 12v?
Mason alarm: this has stopped working as it used to, now screeches when ign is tuned on and goes out when engines is started. Turning the temperature control also sees to have no effect now. I thought the temp control used to have a stop but it just rotates all the way around. Anyone else had this issue and managed to solve? Am about to take the van to Wales for a week! Thanks.
Haydn Alarms
Re: Coolant alarm(s) help
Post by Haydn Alarms » Fri Jul 29, 2016 11:21 pm
The Red/Black Wire on a Haydn Alarm is Negative which goes to the vehicles EARTH, the solid Red is POSITIVE and must be connected to a fused connection that switches on and off with the ignition.
If you get in touch on [email protected] i'll send through a electronic copy of the instructions so you have all the info.
Hope this is helpful any other problems just get in touch if I can't answer your questions I'll get Dad/Haydn to help.
I'm sorry I can't help with the Mason Alarm.
Jo @ Haydn Alarms
Ahead
Post by Ahead » Sat Jul 30, 2016 11:14 am
Great, thanks Jo. I should be fine with this the other wires are secure.
