Central locking motor
Mickybrom
Post by Mickybrom » Sun Jul 24, 2016 5:55 pm
Hi folks.... My passenger door central locking motor has stop working. I've taken the motor out and opened it up and the plastic cog and screw mechanism has snapped. Enquiries suggest nearly £300 to import a new motor and I can't locate one at a breakers.
Anyone know if the motor is shared with any other model or if the 'cog and screw' is common to other motors? Seems a simple job to swap this part if I can find one?
Thanks.
Re: Central locking motor
Post by Bob » Sun Jul 24, 2016 6:39 pm
Have you tried George at Bongo Spares?
Post by rita » Sun Jul 24, 2016 7:08 pm
Post by mikeonb4c » Sun Jul 24, 2016 7:36 pm
Blimey is that a central locking motor :shock:
Post by Bob » Sun Jul 24, 2016 8:42 pm
That seems to be the wndow mechanism rather than the door lock solenoid, but I stand to be corrected.
Post by rita » Sun Jul 24, 2016 10:57 pm
Yes you are correct that is the window mech as the advert says, I was only using that as a link to the ebid site.
Good luck.
Post by teenmal » Sun Jul 24, 2016 11:33 pm
Mickey,I have heard of a few people doing a modification by fitting a solenoid / actuator .
Post by Bob » Mon Jul 25, 2016 9:09 am
rita wrote:Yes you are correct that is the window mech as the advert says, I was only using that as a link to the ebid site.
Good luck.
Ahh, makes sense. :wink:
Bongolia
Post by Bongolia » Mon Jul 25, 2016 9:47 am
Do you mean the sliding door closing motor? Isn't the passenger front door just solenoid operated?
Post by teenmal » Mon Jul 25, 2016 10:05 am
Its a motor, and when the mechanism gets a bit dry etc the plastic drive goes TU .
Post by teenmal » Mon Jul 25, 2016 10:09 am
teenmal wrote:Its a motor, and when the mechanism gets a bit dry etc the plastic drive goes TU ,but I believe it could be replaced with a Solenoid/Actuator.
Bongolia
Post by Bongolia » Tue Jul 26, 2016 8:23 am
Blimey, its a motor!
You learn summit new everyday :)
Well why on earth do they employ a motor?
Could the OP not convert to a solenoid?
Anyone got a picture of that unit?
Titan1995
Post by Titan1995 » Tue Aug 02, 2016 1:52 pm
I have a spare Bongo that I am breaking for spares....if you are fairly local could sort something out for you
stuc
Post by stuc » Wed Aug 03, 2016 11:46 am
I've just fitted one, from George at Bongo spares, next day delivery. Mine would operate downwards to lock once then wouldn't unlock. when opened up it appears to run very slowly so not enough torque to power the lock up.
Strange set up.
Neil1980
Post by Neil1980 » Fri Oct 07, 2022 3:03 pm
Hi, I'm having some issues with centrallocking, suspected solenoid so passenger door central locking not working. All other doors operate correct
Tested voltage and connector plug behind door card, so proves wiring loom in door is intact it seems OK, haven't removed any of the solenoid mechanism as trying to find a guidance video to show me step by step. If anyone has a link that would be great.
When you fiddle with rods, the first time you use central locking you can see movements in the lock on the passenger door, but nothing afterward.
Any suggestions, should I remove the solenoid and investigate further?
