gear box whine
Our Bonnie
gear box whine
Post by Our Bonnie » Sun Jul 17, 2016 12:00 am
Have posted about a little LPG issue, so thought I would go the distance and mention a whine, or fairly high pitched musical hum if our Bongo is loaded and we drive up a hill, or accelerate. No noise at all if lightly loaded.
Did a search on the forum, and came across a power steering issue (no problems there, fluid good) and also a possible rear diff?
Would value any thoughts.
best wishes
Kevin
p.s. 2000 V6 petrol, Romano LPG
Re: gear box whine
Post by mikeonb4c » Sun Jul 17, 2016 10:15 am
Our Bonnie wrote:Have posted about a little LPG issue, so thought I would go the distance and mention a whine, or fairly high pitched musical hum if our Bongo is loaded and we drive up a hill, or accelerate. No noise at all if lightly loaded.
best wishes
Kevin
I have a very slight high pitched whine/whistle that first appeared a few years ago. Its only at certain speeds in gears and when under load. I'm pretty sure its gearbox related. At first i worried about gearbox failure but it never happened and now, many thousands of miles later (and as its so slight) i pay it no heed. No idea what brought it on though.Does the speed at which yours happens vary with which gear you're in? If not then maybe its more diff related?
Re: gear box whine
Post by Bob » Sun Jul 17, 2016 10:55 am
This is possibly normal turbo noise. [-o<
Re: gear box whine
Post by mikeonb4c » Sun Jul 17, 2016 12:30 pm
Bob wrote:This is possibly normal turbo noise. [-o<
Possible Bob but i've pretty much discounted that. I think though that after all this time and miles it must be judged as non threatening, and it is barely noticeable. The OPs noise might be different though so maybe he needs to get a mechanics opinion.
Our Bonnie
Re: gear box whine
Post by Our Bonnie » Mon Jul 18, 2016 12:00 am
many thanks for the replies.
Basically, when there's four of us, 2 adults, 2 teenagers plus day trip stuff, then when accelerating away, sometimes on the flat or uphill, then the whine, or a high pitched 'musical hum' appears, and is fairly loud and is in about 2 or 3 gear, ease off slightly and disappears.
We had the transmission fluid replaced a few months ago, so confident its at the right level. No juddering, slipping and acceleration is fine, so thinking its sounds more alarming than what it is.
48,000 miles, 2.5V6 petrol.
cheers
Kevin
cmm303
Re: gear box whine
Post by cmm303 » Mon Jul 18, 2016 8:55 am
Replacing (not just topping up) oil in diff is a cheap thing to eliminate and good maintenance anyway.
Chris with BertieB
mikeWalsall
Re: gear box whine
Post by mikeWalsall » Mon Jul 18, 2016 1:16 pm
Alternator bearings .. drive belt ..??
cmm303
Re: gear box whine
Post by cmm303 » Mon Jul 18, 2016 2:37 pm
mikeWalsall wrote:Alternator bearings .. drive belt ..??
could check stationary as this would show up with engine revs irrespective of gear and engine load?
Chris with BertieB
Our Bonnie
Re: gear box whine
Post by Our Bonnie » Tue Jul 19, 2016 5:41 pm
Many thanks for your replies, it's going to a certain friendly expert at Plymouth :D to have some TLC. Will also have our presumably leaky air con looked at as well, just in case it can be repaired.
cheers
Kevin
Re: gear box whine
Post by mikeonb4c » Tue Jul 19, 2016 6:29 pm
Our Bonnie wrote:Many thanks for your replies, it's going to a certain friendly expert at Plymouth :D to have some TLC. Will also have our presumably leaky air con looked at as well, just in case it can be repaired.
cheers
Kevin
Good decision - can't do better than take it to the Plymouth Brethren ;-)
