D r l
Moderator: Ian
grey fellah
D r l
Post by grey fellah » Tue Jun 28, 2016 1:39 pm
02 tin top, has anyone adapted front fog lights to d r l''s . Thanks in advance for any info
Re: D r l
Post by mikeonb4c » Tue Jun 28, 2016 3:35 pm
grey fellah wrote:02 tin top, has anyone adapted front fog lights to d r l''s . Thanks in advance for any info
I thought this was a post about Dr. I the legendary Jamaican rapper, until I read the content :lol:
What are d.r.l. s? :-k
stuc
Re: D r l
Post by stuc » Tue Jun 28, 2016 3:47 pm
Would be easy enough to do though.
Re: D r l
Post by Bob » Tue Jun 28, 2016 6:36 pm
Daylight Running Lights, the LEDs fitted to modern cars. :wink:
Re: D r l
Post by mikeonb4c » Tue Jun 28, 2016 6:41 pm
Aha! Thank you Dr. Bob the legendary West Country rapper. :lol:
Gefail
Re: D r l
Post by Gefail » Tue Jun 28, 2016 8:00 pm
Hello,
I fitted a set of drls in the grille of our tintop. Full set £35 off Fleabay.
If you swap your fog bulbs for led versions you just need a drl control module (less than £10)
It connects to battery via fuse, a wire to dipped beam to dim them at night and option to flash the lamps in unison with the indicators.
Its voltage sensing so on when engine starts and off after a delay when engine stops. No problem with mot, just passed last week.
02-07-1999 TinTop 2WD Oil Guzzler with Hyper Seat :shock:
callum
Re: D r l
Post by callum » Tue Jun 28, 2016 11:30 pm
I should bw fitting some this week, so i'll keep you posted. I don't have fogs, so i have bought some universal ones wirh an angel eye DRL. As mentioned, the loom thingy is also needed, but they are cheap, ao hopefully should be an easy fit.
This is what i have bought for the lights
http://www.ebay.co.uk/itm/161790752624
And this is the wee loom
http://www.ebay.co.uk/itm/152027172379
I am hopeful that i'll have it all fitted in a hour or so. Depends on how easily i can cut the holes in the bumper!
cmm303
Re: D r l
Post by cmm303 » Wed Jun 29, 2016 8:04 am
Does this mod need notifying to the insurance company?
Chris with BertieB
Diplomat
Re: D r l
Post by Diplomat » Wed Jun 29, 2016 9:31 am
I thought it might be about expensive headphones.
Frank
They flew, I took up naturism
callum
Re: D r l
Post by callum » Wed Jun 29, 2016 10:05 am
Regarding insurance, i can't see it being any different to fitting non original fogs. It's basically retrofit rather than a mod for performance or making it more desirable for theft.
I may mention it at insurance time, but as it is an import, with camper conversion, i'm not thinking that drl's will be a contributing factor to (already) high insurance.
grey fellah
Re: D r l
Post by grey fellah » Wed Jun 29, 2016 12:14 pm
callum wrote:I should bw fitting some this week, so i'll keep you posted. I don't have fogs, so i have bought some universal ones wirh an angel eye DRL. As mentioned, the loom thingy is also needed, but they are cheap, ao hopefully should be an easy fit.
hi, i sorted wiring some time ago. but lamps i used were rubbish, hoping 2 change lamps in fog lights & reconnect,wondered if anyone had done this, & wot they used, thanks 4 your replies. i'll keep the lights you are using in mind as another option, good luck on the hole cutting ! thanks ray
jaylee
Re: D r l
Post by jaylee » Tue Sep 06, 2016 11:43 pm
Funny enough. I just got this loom that Callum found. The plan is to use the front factory fogs on my 02 plate as DRLs that will turn off with headlight use. But switched on for the intended foglight use with the dipped beam..?! A bit like my wife's Nissan Note..
helen&tony
Re: D r l
Post by helen&tony » Wed Sep 07, 2016 3:49 am
Please be aware that you must have properly "E" marked DRLs if you intend to use them as such in any country requiring them. I believe in some countries require that they should have a fitting certificate of compliance if used as DRLs. The proper DRLs are extraordinarily bright in comparison with most LED offerings. They should also dim when lights come on, AND you should only run one set of marker lights, DRLs and not with sidelights as well.
jaylee
Re: D r l
Post by jaylee » Wed Sep 07, 2016 7:46 am
helen&tony wrote:Hi
Hi Hellen,
That's a fair point about using aftermarket DRLs abroad. (Outside the UK.)
I know in Poland one was legally required to drive with the heads lights on by day.. I always find if in doubt? (On the continent.) Drive it like an old school Volvo! (The same law probably applied in Scandinavia too?)
... Especially in a big black brick. :D
Gasy
Re: D r l
Post by Gasy » Wed Sep 07, 2016 6:55 pm
I've just swapped my original fogs for these
Don't think there drl as have halogen bulbs in
But we're only a £1 a pair from halfords
Return to “Pimp My Bongo”
