Coolant level
- Apprentice Bongonaut
Coolant level
I'm in the process of renewing my coolant but I can't see the level in the header tank.if I dip a stick in how far up should it register for full and low
Re: Coolant level
just measure the marks on the outside from the bottom of the tank, knock a tad off for the thickness of the base of the tank.
Re: Coolant level
Spot on, Ady.
I think Haydn says 3/4" or 20mm on a lolly stick.
- haydn callow
Re: Coolant level
20mm when stick is vertical. Or fit a Low Coolant Alarm and let it do the measuring for you.Karensmyth wrote:I'm in the process of renewing my coolant but I can't see the level in the header tank.if I dip a stick in how far up should it register for full and low
