We have a single Reich "De-Luxe" tap in the van with a Whale submersible pump. Recently, operation has become intermittent. We can hear the microswitch click as we turn the tap but the pump doesn't always operate. After trying a few times it then normally starts working again.
Any ideas whether the problem is likely to be the tap, the pump or something else (the pipe maybe)?
Intermittent tap problem
- Jimbobvfr400
Re: Intermittent tap problem
It's a guess but I'd say pump or wiring but I'd start by testing the switch.
Jamie, Caroline and the kids.
2002 V6 Aero AFT
2002 V6 Aero AFT
I had the same issue, intermittent working gradually getting worse. Had a bit of a try at ruling out the various parts by a process of elimination. My power is via a 12v socket in the back so tried that with my powered cool box to prove i had current. Checked the pump by disconnecting the tap and powering it directly from the conections on the electrical block that joined everything together. Quickly realised the tap was at fault despite the microswitch click. Sealed unit so just bought a new one for £13 off eBay, fitted, and I can now reliability fill my kettle again
Thanks for the replies. The tap does seem the most likely culprit. Oddly, it worked OK most of the time this weekend but if it gets worse again I'll replace the tap.
Cheers,
Shaun
Cheers,
Shaun
