Air lift bags on a side conversion
cushers
Post by cushers » Fri Jun 03, 2016 7:15 pm
Bags have arrived. Any advice on fitting?
Pressures?
Graeme
Re: Air lift bags on a side conversion
Post by g8dhe » Fri Jun 03, 2016 9:05 pm
I got the garage to fit them :D
Run about 15psi in them, started much higher, and slowly let them down, until the thumping came back then put them back up again.
cushers
Post by cushers » Fri Jun 03, 2016 9:17 pm
Hi Geoff
Thanks again. No bumping in this case. Just planning on reducing body roll.
Graeme
Propnut
Post by Propnut » Fri Jun 03, 2016 9:55 pm
cushers wrote:Bags have arrived. Any advice on fitting?
Pressures?
Graeme
Fitted mine myself. Don't believe the instructions that tell you to roll them up and insert them in through the side of the spring. I removed the lower shock absorber bolt to allow the track arm to move lower then used Spring compressors to remove the spring and inserted the bag from the end. I secured the pipe work to the brake pipe above the axle and installed both valves at the rear end of the side door step. I run 25 psi both sides when towing.
Great advice and pictures here:- http://igmaynard.co.uk/bongo/forum/view ... ft#p620887
cushers
Post by cushers » Sat Jun 04, 2016 9:31 am
Thank you Propnut.
Have seen that thread but wondered if thinking had changed. Will invest in a spring compressor.
Graeme
Post by Simon Jones » Sat Jun 04, 2016 7:30 pm
Screwfix do spring compressors for about £18 and are essential to get the bags in without risking damage. The pipes should go downwards and along to wherever you decide to put the valve(s). I used a T-piece and fitted the valve inside the wheelarch but tucked out the way of all the mud and water.
Jillygumbo
Post by Jillygumbo » Mon Jun 06, 2016 1:14 pm
Since carrying two adults in the back of Tonto since conversion, I have decided that air assisters should be considered. Jon and Gema had a very ride to Stratford and back!
I've looked on the net and can find Air Lift at £83.33 exc VAT (and delivery presumably) and MAD-Suspension for £217.56.
Other than cost, what is the difference between these 2 please? Anyone know?
Jillygumbo, Marvin & Lady
cushers
Post by cushers » Mon Jun 06, 2016 4:43 pm
Jillygumbo, The Mad suspension set looks very similar to my kit that cost approx £100 from a different supplier. I have not however any experience of using them so there could be something that makes them a further £100 better.
Good luck and Im sure someone will be along who can provide more clarity
Graeme
cushers
Post by cushers » Mon Jun 06, 2016 4:56 pm
So,
I am all prepped for bag fitting (Spring compressors, axel stand).
Final call for suggestions.. Bearing in mind it's a side conversion (fridge, 2 ring gas burner, EHU fitments, cupboards, Gas cylinder and RnR bed)
Options
- linked via the T piece OR independent inflation valves
TIA
Graeme
Propnut
Post by Propnut » Mon Jun 06, 2016 7:20 pm
Mine is like yours with the full side conversion, water tank, fridge, etc etc. I also use it for towing so added the airbags about a year ago, to help the back end a bit. I ran separate lines just to give me options as with a side conversion most of the weight is on the drivers side. I mounted the valves in the rear face of the rear side step inside the van. Out of the way of road muck and easy to get to.
Good luck, it's not a difficult job to do just be careful where you run the pipe work, watch out for potential pinches and chafes.
cushers
Post by cushers » Mon Jun 06, 2016 10:13 pm
Thanks again Propnut.
Did you have any chafing issues as you went through the rear arch rubber Bing and hole covered by tape in the step?
Did the airlines fit side by side ok?
Graeme
Post by Bob » Tue Jun 07, 2016 12:11 am
Got mine in the garage, just need to fit them. 8)
Propnut
Post by Propnut » Tue Jun 07, 2016 8:08 am
cushers wrote:Thanks again Propnut.
Graeme
I ran the pipes along the radius arms leaving a good free loop as it ran off the end to allow for movement of the arm. I also used a piece of plastic edge trim as protection on the flange of the radius arm pivot bracket where the pipes passed close by. I removed the plastic step trim panel and drilled a hole at the back of the opening to pass the pipes through I used a rubber grommet to protect from the edge. The valves are mounted in the plastic step trim panel one above the other. I'll try to post some pictures later.
cushers
Post by cushers » Tue Jun 07, 2016 4:24 pm
Thank you all for the help.
Invade anyone else can use this thread
I have just fitted the air lift set to my side conversion this afternoon. I'm no mechanic and took about 90min / side. I have rigged them to be independent of each other.
Seriously consider getting a set of Spring compressors. Easy DIY job.
Graeme
Propnut
Post by Propnut » Tue Jun 07, 2016 8:53 pm
Glad to hear it went well, sounds like you're pleased with the results. I have been having trouble posting a pic of my install so its good that you managed without it.
Just a word of caution to anyone else about to do this job. It's well within the capabilities of most however the most dangerous part is handling the spring with the compressors on. Take great care as it's not unknown for them to slip resulting in the spring exploding from their grasp. Don't let this put you off just handle the compressed spring gently with great care and try to keep hands out of the way as much as possible.
