Changing front map or courtesy light bulbs
Posted: Wed May 11, 2016 7:50 pm
by BillyCasper
Evening,
How do you change theses bulbs? Pop out the transparent lens? It seems very stiff and brittle and I don't want to force it and break it. Or, take out the whole unit from the lining, which I did, but then how do you get to the bulbs?
Regards
Re: Changing front map or courtesy light bulbs
Posted: Wed May 11, 2016 8:12 pm
by cmm303
Posted: Wed May 11, 2016 9:04 pm
by BillyCasper
Great, thanks for the link.
Posted: Thu May 12, 2016 8:49 am
by mikeWalsall
Posted: Thu May 12, 2016 9:11 am
Well worth doing this:
http://igmaynard.co.uk/bongo/forum/view ... hilit=foil
....while you have the unit out
Posted: Thu May 12, 2016 10:25 am
by wonkanoby
Posted: Thu May 12, 2016 1:24 pm
Neat product at amazing price
I had LEDs in for a while but missed the warmth of the filament light and, more importantly, got fed up with the flickering when an LED failed and the dim glow they gave out when everything was off (all discussed on here - it seems LEDs can excite even with v low current flow).
At that price though its gotta be worth a try!
Posted: Thu May 12, 2016 11:29 pm
by Simon Jones
Bear in mind that if you have an alarm that is triggered by voltage drop caused by the interior lights coming on when the doors are opened that it may not trigger due to the low current drain.
