Evening,
How do you change theses bulbs? Pop out the transparent lens? It seems very stiff and brittle and I don't want to force it and break it. Or, take out the whole unit from the lining, which I did, but then how do you get to the bulbs?
Regards
Changing front map or courtesy light bulbs
BillyCasper
- Bongonaut
Re: Changing front map or courtesy light bulbs
You're on the right track. this thread may help: http://igmaynard.co.uk/bongo/forum/view ... ht#p599365
Chris with BertieB
BillyCasper
- Bongonaut
Great, thanks for the link.
- mikeWalsall
Well worth doing this:
http://igmaynard.co.uk/bongo/forum/view ... hilit=foil
....while you have the unit out
Neat product at amazing pricewonkanoby wrote:http://www.ebay.co.uk/itm/T10-BA9S-194- ... SwBahVeVcA
stick them in if you want bright
At that price though its gotta be worth a try!
- Simon Jones
Bear in mind that if you have an alarm that is triggered by voltage drop caused by the interior lights coming on when the doors are opened that it may not trigger due to the low current drain.
