Anti roll bar linkage
psquiddy
Post by psquiddy » Wed May 04, 2016 4:02 pm
I got an advisory on the MOT: "Anto roll bar linkage has slight play in pin/bush nearside rear."
Is this a diy or garage job? (Any special tools needed?)
Which parts am I likely to need?
I assume I should do both sides at the same time.
Ta in advance.
Over 300 free things to do in London
http://www.toplondondaysout.co.uk
Re: Anti roll bar linkage
Post by Northern Bongolow » Wed May 04, 2016 7:39 pm
heres the back axle.
http://lushprojects.com/bongopartsmk2/c ... 1of02.html
heres the anti roll bar and drop links, i presume he meant the bolts that go through the drop links, the little bushes that are at each end of the drop links wear badly, mumber 2b-170b on the drawing. (get gen mazda ones not cheap ones)
