I am hoping you can help me with diagnosing a problem on my 1998 2.5 V6 Auto petrol Bongo. My Bongo is behaving a little sluggish and the revs varying, they drop even lower when reversing. Also it seems that the problems only really start happening when the vehicle has been running for 5 minutes. I will put my foot down a little on the accelerator to increase power a little, say when exiting a roundabout, not to kick down but just to speed up and nothing happens so I press a little more and the next second the revs jump to 3000 and its off like a shot. After doing much reading on the web about possible reasons why a little I decided to lift the seats and have a look myself.
First thing looked at was the plugs, I removed all 6 and replaced with new. They seemed to be black although not fluffy stuff so perhaps it is running a little rich, I reckon it has been drinking a bit more than usual lately too so might fit. However changing the plugs has made no obvious difference. I inspected the leads too and they look in reasonable shape, no splits etc.
I checked the air filter and this was in good shape too.
I have also took up the slack in the throttle cable (not to piano wire standard mind)
I read about the diagnostic port and connected up an LED and made necessary loop to look at the engine codes, there were quite a few and some could have been old so I cleared them out and am now left with the following, 11, 12, 15 and 11 again it seems.
The throttle position sensor shows up in the diagnostics (12) so have made various measurements to see if it is perhaps that and this where I really need some help.
Ian kindly sent a few pages from a workshop manual and although slightly different to my setup it did help me make the necessary measurements. So with the connector to the TPS disconnected then I have the following voltages on the four connector pins:
~0v on pin number 4 (black/blue)
12v on pin number 3 (Brown)
5.13v on pin number 2 (orange/blue)
5v on pin number 1 (white/black)
so then reconnecting to the TPS and switching the ignition on with throttle closed, measurements on what I think is TCM according to wiring diagram at least on
0v on TCM port 2M (other end of pin 3) (Brown)
0.622v on TCM port 2T (other end of pin 2) (orange/blue) (start of the 'sweep')
5v on TCM port 2A (other end of pin 1) (white/black)
with Throttle open then:
12.22v on TCM port 2M (other end of pin 3) (Brown)
3.791v on TCM port 2T (other end of pin 2) (orange/blue) (end of the 'sweep')
The 'sweep' when opening the throttle looks smooth but does the range (0.622v to 3.791v) look limited ? Maybe I should be achieving 0.5v to 4.5v but no amount of TPS manipulation sees a higher voltage than 3.9v.
This is my first forum post and attempt to look at faults on my bongo so any help appreciated, certainly learning lots.
cheers,
