Cam Belt
tom.bell
Cam Belt
Post by tom.bell » Sat Apr 30, 2016 6:54 pm
Whilst travelling down the M6 at 70ish mph in the 3rd lane (true honestly), I lost power and managed to coast to the hard shoulder. To cut a long story short I was recovered home and the mechanic fetched it to the garage the next day. I was informed my cam belt had broken. Is anybody able to tell me if my engine is likely to be 'foobar' and the likely cost of repairing/replacing it ? I have a 2005 Aero City Runner auto 2.0ltr petrol.
Re: Cam Belt
Post by Northern Bongolow » Sat Apr 30, 2016 10:21 pm
according to this thread you may just be in luck bud. [-o< [-o< .
http://igmaynard.co.uk/bongo/forum/view ... it#p620503
tom.bell
Re: Cam Belt
Post by tom.bell » Sun May 01, 2016 3:34 pm
Thank you for pointing me in that direction, will keep my fingers crossed when he gets to have a look at it this week, hopefully !!
lpgimports
Re: Cam Belt
Post by lpgimports » Fri May 06, 2016 3:34 pm
A few years ago we had a AFT 2.0 which we took in part exchange, it had a new cambelt supposedly the year before from a well known campervan conversion centre, the belt let go when we sold it on on stripping it hadn't been replaced, the head had to come off and I think two valves needed to be replaced. The FE engine is an interference engine, if you get away with it you were just lucky.
Re: Cam Belt
Post by teenmal » Mon May 09, 2016 8:58 am
According to the little red book....
Mazda 2.0L SOHC Non-Interference
tom.bell
Re: Cam Belt
Post by tom.bell » Fri May 20, 2016 7:44 pm
Well it's been a couple of weeks and my apologies for not posting a reply sooner. Bongo is all good with no damage to engine and cam belt replaced. So if you have a 2ltr bongo and your cam belt goes it won't damage the engine and will just need replacing, however when your mechanic does it make sure he sets it to No.2. Apparently there are 4 settings, whatever this means !! Basically won't start if set to 1,3 or 4 and saves the mechanic from taking it on and off each time. If you are ever in South Cumbria and break down then Google Yewbarrow Garage in Grange over Sands and he will come and fetch you and hopefully fix broken Bongo. Best garage in South Lakes by far and I use them frequently to fix my Fourtak.
mikeWalsall
Re: Cam Belt
Post by mikeWalsall » Sat May 21, 2016 1:33 am
Unlike the diesels .... both the 2.0 and 2.5 Petrol engines are Non-Interference fit engines so the pistons should not smack into the valves if the cam belt goes ..
Re: Cam Belt
Post by Bob » Sat May 21, 2016 1:45 pm
Great news. =D>
Blakey1972
Re: Cam Belt
Post by Blakey1972 » Mon Feb 12, 2018 12:52 pm
Hi I have a Japanese imported V6 Petrol aft,can anyone confirm if it has an interference engine please.
Re: Cam Belt
Post by Bob » Mon Feb 12, 2018 2:14 pm
Mike Walsall, above, says it's non-interference.
And welcome to BF. 8)
TheLongRoad
Re: Cam Belt
Post by TheLongRoad » Mon Feb 12, 2018 3:03 pm
tom.bell wrote: Fri May 20, 2016 7:44 pm .....however when your mechanic does it make sure he sets it to No.2. Apparently there are 4 settings, whatever this means !! Basically won't start if set to 1,3 or 4 and saves the mechanic from taking it on and off each time. If you are ever in South Cumbria and break down then Google Yewbarrow Garage in Grange over Sands and he will come and fetch you and hopefully fix broken Bongo. Best garage in South Lakes by far and I use them frequently to fix my Fourtak.
Thanks for the little gem about fitting to settings on No 2 cyclinder, also maybe Yewbarrow Garage in Grange over Sands should be added to the 'good garages' list if they are not already recorded there. =D>
2002 Friendee 2.0 ltr Petrol.
