Tyre pressures
wyefish
Tyre pressures
Post by wyefish » Thu Apr 28, 2016 12:48 pm
I have 215/55 17 tyres all round on my Bongo. I'm a bit unsure as to the correct pressures to apply. Your collective wisdom would be most helpful!
Re: Tyre pressures
Post by Bob » Thu Apr 28, 2016 1:41 pm
I have standard steel wheels and run 38 psi front 40 psi rear.
There is a calculator for caravan tyres which is worth a look:
https://caravanchronicles.com/guides/ca ... r-caravan/
Just remember Bongy has 4 wheels, not 2. :wink:
roosmith
Re: Tyre pressures
Post by roosmith » Thu Apr 28, 2016 1:44 pm
As you're not running standard wheels it might have to be a bit of experimenting however I have run 18" and now 15" and have both of them set to 40psi all round for convenience but also because it seems to give best suspension/fuel economy etc
Jillygumbo
Re: Tyre pressures
Post by Jillygumbo » Thu Apr 28, 2016 1:56 pm
I tend to stick to 40 all round as I'm usually carrying a bit of weight (Don't go there) or towing a small trailer. Plus - it's easier to remember!
Jillygumbo, Marvin & Lady
roosmith
Re: Tyre pressures
Post by roosmith » Thu Apr 28, 2016 4:28 pm
I think all Bongo's carry a bit of weight to be fair Jilly!
(PS that was very tongue in cheek earlier on the now locked post, just very fed up with the negativity)
wyefish
Re: Tyre pressures
Post by wyefish » Thu Apr 28, 2016 5:29 pm
Thanks to everyone! Good advice, as usual. I'm off with the old girl on a boat to Spain on Saturday. Hoping to spend a bit of quality time touring around with my two best girls (one being our faithful old Bongo).
