Mystery wire by alternator
Rapidair65
Post by Rapidair65 » Sat Apr 09, 2016 3:45 pm
I'm replacing the driver side steel heater pipe and, while inspecting the underside I noticed a single wire which was not connected. It has a right angled socket on the end which looks like it fits onto a post type pin. I thought at first it was the engine temp sensor but that is a spade connector. Is there a single pin connector on the alternator?
1998 green and silver V6 called 'Blossom'
2004 white 2 litre tin top called Buzz.
Re: Mystery wire by alternator
Post by Northern Bongolow » Sat Apr 09, 2016 6:12 pm
look at the very last post on this link. the answer is yes.
http://www.igmaynard.co.uk/bongo/forum/ ... mp#p668883.
there is also a single wire from the aircon unit which is close by.
Rapidair65
Post by Rapidair65 » Sat Apr 09, 2016 7:21 pm
That could be the answer. The van has been flattening batteries for some time. I will have a look tomorrow. Thank you for your help.
Post by g8dhe » Sat Apr 09, 2016 7:51 pm
Yes there is one two pin connector and then a separate single pin they are labelled A1-02 in the diagram and connector layout below;
The Black/Red is the field current feed that generates the magnetic field, without that you will get only a very feeble result!
Rapidair65
Post by Rapidair65 » Sun Apr 10, 2016 5:14 pm
Thanks Geoff, I've had a look at the alternator and can't see a single pin connector. The van has had a history of flat batteries so this wire could be the cause. Do you know where on the alternator the connector is located? I can't read the diagram as I'm working on an I phone in the Hebrides and don't have flash player!
Post by Doone » Sun Apr 10, 2016 7:49 pm
Which engine does your Bongo have?
Rapidair65
Post by Rapidair65 » Sun Apr 10, 2016 8:48 pm
The van is a 1998 V6.
Post by Northern Bongolow » Sun Apr 10, 2016 10:05 pm
this should be a v6 alternator, think it maybe wired different.
geoff should know he has one.
http://www.ebay.ie/itm/MAZDA-BONGO-FRIE ... Swf-VWbnUp
Post by Simon Jones » Sun Apr 10, 2016 11:23 pm
If you're stuck, I'll pop the seat up on mine and take a photo for you tomorrow evening.
Rapidair65
Post by Rapidair65 » Mon Apr 11, 2016 9:10 am
It's sorted! The mystery wire is the feed from the power steering pressure sensor. It's tucked away on top of the pump and refitting it will be somewhat difficult. The pump may have to come off. Thanks to everyone for the help.
helen&tony
Post by helen&tony » Mon Apr 11, 2016 9:32 am
Oh, that's one more thing to check.... :lol: :lol: :lol: :lol:
Post by Northern Bongolow » Tue Apr 12, 2016 1:52 am
Rapidair65 wrote:It's sorted! The mystery wire is the feed from the power steering pressure sensor. It's tucked away on top of the pump and refitting it will be somewhat difficult. The pump may have to come off. Thanks to everyone for the help.
never heard of it, so it must put a light on then. do we all have em. too many questions. #-o #-o :wink:
i want one :^o .
petrol
http://lushprojects.com/bongopartsmk2/c ... 2of02.html
diesel.
helen&tony
Post by helen&tony » Tue Apr 12, 2016 4:32 am
Looks like that's saved me a job! :lol: :lol: :lol: :lol:
Post by Northern Bongolow » Tue Apr 12, 2016 11:14 am
me too. always thought them petrols were trouble. :^o :lol: :lol: :lol: :lol:
