Wiring, Series or Parallel
TheStinkyHippy
Post by TheStinkyHippy » Mon Mar 28, 2016 3:15 pm
I was thinking, I wonder if I have wired up my roof lights wrong.
Coming into the corner of the AFT is the connection for the downstairs main light.
I wired some LED lights into the roof a long time ago..
Basically I wired them in parallel.
Code: Select all
----+ve wire   ---|connector|-----|
                                 main light
-----ve wire -----|connector|-----|
was changed to
Code: Select all
----+ve wire   ---|(wireA)connector|-----|
                                         main light
-----ve wire -----|(wireB)connector|-----|
Code: Select all
wireA------------|
                  LED lights
wireB------------|
I wonder if I should have done,
Code: Select all
----+ve wire   ---|(wireA)       (wireB)-----|
                                          main light
Thoughts?
jimmo62
Re: Wiring, Series or Parallel
Post by jimmo62 » Mon Mar 28, 2016 4:42 pm
Assuming they are 12v LED lights then wiring in parallel as you have done is correct
Post by Simon Jones » Mon Mar 28, 2016 5:24 pm
If you wire in series you'll only get about half the voltage at each light and if one ever fails, the other(s) will go out too. You also risk blowing the LED lights with the current drawn by the other light as it will effectively act like a fuse.
Post by Bob » Mon Mar 28, 2016 7:22 pm
Just like the old type Christmas tree lights. :wink:
