What coolant
Adscan
What coolant
Post by Adscan » Sat Mar 26, 2016 10:56 pm
I want to replace the coolant in my 2.5td Bongo. What is the recommended type?
Re: What coolant
Post by Northern Bongolow » Sat Mar 26, 2016 11:06 pm
this one is good and a great price, its the correct OAT chemical makeup.
ready mixed.
http://www.eurocarparts.com/ecp/p/car-a ... &0&cc5_866
concentrate.
5 year too. 8) 8)
Re: What coolant
Post by Bob » Sat Mar 26, 2016 11:17 pm
Please?
cmm303
Re: What coolant
Post by cmm303 » Sun Mar 27, 2016 10:17 am
If you are currently running non-OAT antifreeze you must flush out the system thoroughly before installing OAT antifreeze because they don't mix. Draining the system alone isn't enough to clear out the old coolant, at best it'll leave 1-2 litres behind, at worst a lot more.
Chris with BertieB
Fassi
Re: What coolant
Post by Fassi » Sun Mar 27, 2016 10:46 am
cmm303 wrote:If you are currently running non-OAT antifreeze you must flush out the system thoroughly before installing OAT antifreeze because they don't mix. Draining the system alone isn't enough to clear out the old coolant, at best it'll leave 1-2 litres behind, at worst a lot more.
what would be the consequences of mixing them? Must admit I don't know what red coolant was in mine to start with and have been using the OAT one here the last couple of times I've bled and burped the system without a complete flush.
1995 2.5 TD
cmm303
Re: What coolant
Post by cmm303 » Sun Mar 27, 2016 2:24 pm
see Q8 here. I've heard it could restrict flow in narrower channels.
Though no guarantee, pink or red is usually OAT. So you are probably ok. Could confirm by checking your coolant is not cloudy. You could drain some off into a clear jar/jug using the drain valve at the bottom of the rad whilst keeping expansion tank full.
Chris with BertieB
Fassi
Re: What coolant
Post by Fassi » Tue Mar 29, 2016 6:53 pm
I'll double check. Thanks
1995 2.5 TD
