There is a pump (I think) of some sort towards the front of the engine on the drivers side. It has a metal 10mm pipe going into the bottom of it with two 10mm bolts. These were drenched in what I think was ATF (certainly wasn't engine oil). The bolts are tight but it could be coming from further up but I couldn't see, as it's all crammed in around this area. I thought the power steering was on the other side of the engine and the fluid level was on the high side of normal anyway. The auto box level was bang in the middle when warmed.
The only thing to add, although fairly confident I can tell the difference between oil and coolant, is I do have an as yet unidentified coolant leak. Every 6 weeks or so I'm having to put 50-100ml of coolant in.
As always I'll be grateful for your replies
