Contact noise when turning right
chrisbearbongo
Post by chrisbearbongo » Mon Mar 14, 2016 10:52 am
I have recently noticed that when i am turning right and the gradient of the road or the intensity of the turn causes the van to lean i get a strange noise like two pieces of metal are spinning against each other. i have looked in the arches and run my hands around the wheels for any signs of contact but there appears to be none. can anybody shine a light please .
chris
Fassi
Re: Contact noise when turning right
Post by Fassi » Mon Mar 14, 2016 10:59 am
chrisbearbongo wrote:Hi
chris
did you do the front brakes recently? I had this a while ago due to some brake pad shims and a bent piece of metal at the back of the calliper. Can't really remember exactly but there was some misalignment.
1995 2.5 TD
chrisbearbongo
Post by chrisbearbongo » Mon Mar 14, 2016 11:03 am
No but i have recently put new wheels on it so maybe this could have caused it ?
Fassi
Post by Fassi » Mon Mar 14, 2016 11:08 am
chrisbearbongo wrote:No but i have recently put new wheels on it so maybe this could have caused it ?
have you checked the nuts are tight and that the wheels are turning freely by hand? :D sorry for stating the obvious
1995 2.5 TD
Post by Bob » Mon Mar 14, 2016 11:12 am
And are the wheels the same as before or, say, alloys instead of steel?
chrisbearbongo
Post by chrisbearbongo » Mon Mar 14, 2016 11:16 am
Thats a good point i haven't re-tightened them yet as they were newly sprayed .
They are different in the fact they are bigger than they were origionaly.
I really appreciate the help here btw. :)
Post by Bob » Mon Mar 14, 2016 11:27 am
Its possible the wheel nuts should be diferent.
chrisbearbongo
Post by chrisbearbongo » Mon Mar 14, 2016 12:25 pm
thanks for the help guys i will look further into it and hopefully the nuts are the reason :)
Post by Bob » Mon Mar 14, 2016 1:38 pm
Do you still have the old wheels you could try, or maybe the spare, and see if the noise goes away?
chrisbearbongo
Post by chrisbearbongo » Mon Mar 14, 2016 3:24 pm
unfortunately i gave them away a couple of days ago :( i will try tightening and have a look for any signs of rubbing around the brake components.
Post by Bob » Mon Mar 14, 2016 7:01 pm
If you're anywhere near me I have a couple of steels you are welcome to try.
chrisbearbongo
Post by chrisbearbongo » Wed Mar 23, 2016 4:10 pm
Hi guys just wanted to give you an update on my issues.
Firstly thanks for the offer of the steelies im in north devon but would have been doable however i am fixed now.
The issue turned out to be simply i needed new break pads on my back wheels.! what had happened was due to the pad wearing it meant a part of the housing was close to the disk so was maki9ng contact at certain angles.
I never had this previously but i have only had this bongo for 6 months as my old bongo was written off outside my house by a dirty VW transporter whilst it was parked up !! but my old model had drum brakes on the rear so i never experienced it! .
Im just glad it was fixable !
I know know however i have an oil leak which looks like its the sump seal :( so its going back under the wrench next payday :(
Post by Bob » Wed Mar 23, 2016 4:38 pm
Glad you're sorted, and thanks for the update.
It really is valuable to hear how an issue is resolved. :)
Post by mikeonb4c » Wed Mar 23, 2016 6:53 pm
chrisbearbongo wrote:Hi guys just wanted to give you an update on my issues.
Great to get your update. I think - though i could be wrong - that all Bongo Friendees have disk brakes all round. The drum you see at the back is for the parking brake only, which does indeed use tbe old shoes/drum principle. Others will no doubt correct me if i've got this wrong.
chrisbearbongo
Post by chrisbearbongo » Wed Mar 23, 2016 9:33 pm
No your right im being a fool i just checked the insurance pics and i did have disks on my previous bongo too! think i'm just getting confused with my wife's car :(
