rear heater matrix removal
poppy2000
Post by poppy2000 » Thu Mar 10, 2016 11:44 pm
Hi, any hints or tips on removal of rear heater matrix on a petrol bongo 2001 would be appreciated. thanks janet from dundee
cmm303
Re: rear heater matrix removal
Post by cmm303 » Fri Mar 11, 2016 12:35 am
Welcome to the forum
There is a step by step posted by stuc in this thread:http://www.igmaynard.co.uk/bongo/forum/ ... er#p672585
Chris with BertieB
poppy2000
Post by poppy2000 » Sun Mar 13, 2016 9:41 pm
Hi, Thanks for your help. Do you know if there is any way to remove and replace rear heater matrix without removing the whole rear heater unit? mine is leaking water and needs replaced. any help would be appreciated. Thanks
Post by Bob » Sun Mar 13, 2016 11:11 pm
Welcome aboard, don't forget the rear heater can be bypassed or blanked off without harm.
You could do this as a temporary fix then come back to it, and don't forget the bleeding process if its a V6- this is vital. :wink:
poppy2000
Post by poppy2000 » Wed Mar 16, 2016 4:39 pm
Hi, Thanks for reply. We are aware the heater matrix can be by passed as a temporary measure. We are looking to do a permanent replacement of heater matrix. We have a 2 litre petrol bongo and its in superb condition so we are not looking for a quick fix. We have seen the heater matrix available on ebay new so purchasing the new part is no problem. We were wondering if the matrix can be removed without having to removing the whole rear heater.Thanks
cmm303
Post by cmm303 » Wed Mar 16, 2016 4:53 pm
This diagram may help your investigations in the absence of anybody coming up with an "I've done it" answer.
http://lushprojects.com/bongopartsmk2/c ... no=.html#4
Alternatively, if you have not done so already, it may be worth doing a careful search of this forum. Search is located in the top right of the page. In the search term try something like
rear AND heater AND (remove OR removal OR replace OR replacing)
The AND's, OR's and brackets are important to get a more accurate result.
Chris with BertieB
dunslair
Post by dunslair » Wed Mar 16, 2016 5:14 pm
From memory (and it was a few years ago we replaced ours after a freeze and burst) you will need to take out the whole housing, which will require you to disconnect the gas line and regas the system as well. I don't think it can be done any other way, but happy to be proved wrong. Its a bit of a pest to get access so be patient. On the positive side the 2 litre is nice and simple to fill up again with coolant since it 'self bleads'. (no uppy downy hosey malarky) ;)
