SmidGe
- Apprentice Bongonaut
Post
by SmidGe » Mon Mar 07, 2016 1:13 pm
Hello bongo peeps,
I am a newbie and I was hoping that someone could help me?
I own a 2.5L V6 Mazda bongo. I need to get a Cambelt (timing belt) change as it has done over 125,000km a water pump change and a full service. Any idea who the best reliable garage is to go to?
Also is it worth getting a LPG conversion at the same time?
Thank you in advance.
cmm303
Post
by cmm303 » Mon Mar 07, 2016 2:53 pm
Welcome to the forum.
If you let us know where you are people can help you better. Many pop a rough location in their displayed details.
Chris with BertieB
Post
by Bob » Mon Mar 07, 2016 3:10 pm
Welcome to BF.
Allans in Plymouth, Wheelquick in Wigan, others in between.
SmidGe
Post
by SmidGe » Mon Mar 07, 2016 4:39 pm
Ah no worries cheers for the info, I am located in Farnborough, Hampshire
I will update my displayed info. I am not too bothered if I have to travel to get it done, just want to done properly
Thanks again
Post
by Simon Jones » Mon Mar 07, 2016 9:06 pm
I'm near Salisbury and I took mine to Allans in Plymouth for cambelt. Don't forget to have the crankshaft and camshaft oil seals done at the same time as they will need doing.
SmidGe
Post
by SmidGe » Mon Mar 07, 2016 9:50 pm
Thanks for the advice! I will make sure I get those done aswell! How much did they charge you? I got quoted for a full service and Cambelt just under £1000 (by someone else).
Post
by Simon Jones » Mon Mar 07, 2016 11:21 pm
Well, this was about 4 years ago, but the cambelt and oil seals was just north of £500 (that was excluding the hydraulic tensioner which I'd been advised should be good until at least the next belt change). For a full service (all fluids and filters) I would guess it would come in a fair bit less than you have been quoted, but it's difficult to say without seeing exactly what's included.
SmidGe
Post
by SmidGe » Tue Mar 08, 2016 7:49 am
Ok thank you! Really appreciate the info!!
I will
Call Allan's to see what they say. I will
Keep you posted.
jimmo62
Post
by jimmo62 » Tue Mar 08, 2016 9:48 am
Also ADS in Bristol would be worth a look, they also specialise in Bongos
mikeWalsall
Post
by mikeWalsall » Tue Mar 08, 2016 11:09 am
My personal advise on LPG is to get a good converter ... close to you .. Maybe better than doing a round trip of x amount of miles to sort out a little glitch .. lap top tune up .. service etc: ..
Also make sure they are members of the UKLPG network and your motor is put on the LPG register ...
With my last two motors (Bongo and Alphard) I have had a 'spot check' done at my home by a UKLPG guy checking that the installations where up to spec.
New Forest Terrier
Post
by New Forest Terrier » Tue Mar 08, 2016 8:39 pm
Discount Trucks at Ashworth Near Newbury did my V6 cam belt last year. Highly recommended and really know their stuff. Cam belt oil seals and water pump £650. Its running beautifully, was before, but seals just starting to go. The water pump was changed on mileage grounds as it is difficult to get at on a V6.
I have a Prins LPG conversion and was worried it would be disturbed by the cam belt change but all fine. I agree with Mike, use a local converter so you can can easily get it serviced or deal with any problems. Some obscure makes have a total lack of spares, so avoid anything that seems to be fitted by only one place.
SmidGe
Post
by SmidGe » Mon Mar 14, 2016 9:12 pm
Thank you for all your input/advice and help guys! I have gone with discount trucks as it is the closest for me and a good price. Meanwhile whilst my bongo has been at home some trouble makers decided to rip off my wingmirror... And scratched my door all down the side.. Just keeps getting better..
roosmith
- Tribal Elder
Post
by roosmith » Mon Mar 14, 2016 9:23 pm
Re the LPG, I would think about it long and hard. I had my non Bongo done a year ago and have been keeping a spreadsheet on how much I've saved (I run the car for work). And after 25k I'm still £400 short of breaking even on the conversion cost. This is mainly due to the worse MPG on LPG ( I get 24 MPG vs 33 on petrol) and my local garages selling LPG for 62p a litre. Also found out that two of them (BP) are stopping LPG as soon as their existing tank full runs out. Unless you do really high mileage and have garages all around you supplying it, it'd think twice.
lpgimports
Post
by lpgimports » Tue Mar 15, 2016 3:18 pm
must be running very rich on LPG
