thermostat
grey fellah
thermostat
Post by grey fellah » Tue Feb 16, 2016 5:32 am
hi, any tips or probs i may come accross when changing the thermostat on my my 2.0 2002 bongo, also any advice on what make or type of stat i would be grateful, thanks
Re: thermostat
Post by Bob » Tue Feb 16, 2016 9:55 am
Parts can be had from the Bongo Shop, not aware of any difficulties doing this.
Re: thermostat
Post by Northern Bongolow » Tue Feb 16, 2016 8:29 pm
these 2 links may help, if you click on the stat number on the drawing it will give you a part number in the left column so you can order the correct stat.
stats on this drawing
http://lushprojects.com/bongopartsmk2/c ... 2of02.html.
rest of the cooling system.
http://lushprojects.com/bongopartsmk2/c ... 1of02.html
Re: thermostat
Post by Northern Bongolow » Tue Feb 16, 2016 8:35 pm
not had much to do with the 2 ltr, just looking at this drawing. is the part number 13-104t (sealing cap) there to aid bleeding or filling ??. the diesel has one fitted to the lowest pipe in the system that runs to the rad from the top hose.?
http://lushprojects.com/bongopartsmk2/c ... f02.html#5
grey fellah
Re: thermostat
Post by grey fellah » Wed Feb 17, 2016 3:38 am
Northern Bongolow wrote:not had much to do with the 2 ltr, just looking at this drawing. is the part number 13-104t (sealing cap) there to aid bleeding or filling ??. the diesel has one fitted to the lowest pipe in the system that runs to the rad from the top hose.?
thanks for the info
