Coolant alarm electrical fault?
Hi folks,
My coolant alarm has been sounding quietly when i push other switches, for example the rear demister. I assume this is an electrical fault as coolant is topped up and fine, just wondered what people would look at first to try and fix it?
Cheer
Callum
Cheer
Callum
Re: Coolant alarm electrical fault?
Could be a combination of the cold weather and the battery getting a bit old.
The sensor is activated by low voltage so the surge when switching on high load accessories could do it.
Ah i see. Well, van hasn't been used much ar all in the last 10 days and it was pretty cold this morn, so that may make sense.
I shall wiggle some connections though to have a gander.
Thanks for the speedy response!
- Simon Jones
It may depend which circuit it is being powered from. As Bob says, it is voltage-dependant so heavy drain on a battery that is not quite fully charged may cause the alarm to misbehave. I wired my alarm to the screw terminals on the rear of the instrument panel which is on a circuit without any great loads to cause a problem.
- haydn callow
When the coolant in the tank is below approx 5C the alarm will often 'mutter' quietly......once the engine has been running a few mins it should go quiet as the coolant warms up.
I have a little bit of this very occasionally (today in fact, two v short blips, and coolant was v cold) despite replacing screws. Touching the brakes usually stops it in its tracks, presumably due to brakelights though darned if i can work out the theory of why!callum wrote:Hi folks,
Cheer
Callum
- haydn callow
Getting close to 20,000 MIke !!
Scary - i can only pass it once. What thenhaydn callow wrote:Getting close to 20,000 MIke !!
Fifty thousand?
One million?
But for the golden pruning shears of destiny being wielded by the moderator of dispair...
One million?
Ye Gods. There's people out there served less time for murder!Bob wrote:Fifty thousand?
One million?
