Help please????
Cab-ova pete
Help please????
Post by Cab-ova pete » Sun Jan 31, 2016 4:36 pm
Help I'm over heating!!!! I noticed she was hot on the gauge so I pulled over!! Header tank is full but other day it was nearer the low mark? What do I do? Do I wait for it to cool down and then move it? No water leaking anywhere! Would appreciate a call desperately!!! On double yellows?
Re: Help please????
Post by rita » Sun Jan 31, 2016 5:12 pm
Cab-ova pete wrote:Help I'm over heating!!!! I noticed she was hot on the gauge so I pulled over!! Header tank is full but other day it was nearer the low mark? What do I do? Do I wait for it to cool down and then move it? No water leaking anywhere! Would appreciate a call desperately!!! On double yellows?
For this reason only, wait for it to cool down and then move it.
Re: Help please????
Post by g8dhe » Sun Jan 31, 2016 5:14 pm
Yes let it cool, don't open the caps until its really cool otherwise you will reduce the pressure and it will boil again! Sounds like a slow leak with air having got sucked in, which is now blocking the flow. You really need to fill and bleed it where you are or consider getting it transported back.
Cab-ova pete
Re: Help please????
Post by Cab-ova pete » Sun Jan 31, 2016 7:32 pm
Hi gdhe thanx for reply, I heard a gurgling sound as she cooled down looked in header tank and no fluid in there, so I squeezed hoses and some fluid appeared in tank! I've moved her and parked her up til tomorrow! The fluid that was still in the system may have saved her? A garage put a new radiator and a steel coolant pipe on in November and I don't think everything was tightened up properly?? I will be having a chat with them tomorrow! :oops: it will be going to my usual garage tomorrow! Anyway thanks for your valuable advice :D
Re: Help please????
Post by Bob » Sun Jan 31, 2016 7:35 pm
Right pain.
Good luck getting sorted. [-o<
cmm303
Re: Help please????
Post by cmm303 » Sun Jan 31, 2016 7:51 pm
Ooh careful moving it. It's not so much about the coolant that is in there but the air that has got in. This air can stop the coolant circulating and cause overheating with all its expensive consequences. If it is at all possible it should be bled without further driving. Appreciating that this may not be possible nor affordable, you could consider topping up, squeezing your pipes :lol: and GENTLY driving for less than <15 mins but this is risky. You might get away with it or It could crack the cylinder head.
Perhaps leave the garage who did the work with the decision and responsibility for consequences?
Chris with BertieB
