Ply Lining Floor - Installers
digitalgypsy
Post by digitalgypsy » Fri Jan 29, 2016 9:31 pm
Hello Bongo friends,
Just wondering if anyone knows of companies that offer a ply lining fitting service for the floor? I'm keen to have as much as insulation as possible and have heard good practice is to have foil (Thinsulate?) beneath the actual ply boards. Anyone know of a good company that offer that sort of fitting?
Thanks very much as always :)
Steve
P.S. Spoke to converters that offer flooring but both said the ply boards provide insulation enough. Hmmmmmm...
Re: Ply Lining Floor - Installers
Post by Bob » Fri Jan 29, 2016 10:26 pm
Depending where you are Madmile, of this parish, AKA Celtic Motorhomes, Caerphilly, is very helpful.
yorkshirelass
Post by yorkshirelass » Sat Jan 30, 2016 11:44 am
I'm thinking of having non slip vinyl type flooring when hi top is done. Am unsure re ply lining as having a dog + water etc if may not last long ??? Have you considered vinyl or just don't like it ? Any probs with it that you know of ?
mikeWalsall
Post by mikeWalsall » Sat Jan 30, 2016 11:58 am
You could specify external grade ply ... or for the ultimate use Marine ply ..
philpdr
Post by philpdr » Sat Jan 30, 2016 1:06 pm
I used laminate flooring underlay then external ply and easily replaceable vinyl tiles to finish.
yorkshirelass
Post by yorkshirelass » Sat Jan 30, 2016 1:33 pm
philpdr wrote:I used laminate flooring underlay then external ply and easily replaceable vinyl tiles to finish.
Gosh, bet that was a lot of hard work !? I think mine will need to be more simple....but yours does sound good.
Pam
digitalgypsy
Post by digitalgypsy » Sun Jan 31, 2016 8:42 pm
Thanks all for input. Yorkshirelass, most converters will lay non slip vinyl flooring as part of the conversion. As Bob notes, Ed at Celtic Motorhomes goes the extra mile in his work and adds some foil insulation beneath the ply boards and vinyl. Think it's definitely worth it for the extra insulation and sound proofing. Hmmm maybe contact Ed to see if he can oblige me :)
philpdr
Post by philpdr » Sun Jan 31, 2016 8:59 pm
Pam
It wasn't that hard,there's a fact sheet in the members area with details.
