I need to replace the coolant temperature sensor (the one in the engine block which controls the radiator fans) but because of the plastic connector I can't get a socket on to remove it.  I've tried two 'deep' sockets, neither was deep enough.  I think an old fashioned spanner may work, but I'll need to remove the air intake hose first.  Before I have to resort to this, has anyone any recommendations for extra deep sockets, or any other ideas!
Many thanks, Andy.
									Removing Coolant Temperature Sensor
- Andy + Cath
 - Apprentice Bongonaut
A+C
White 1997 Friendee AFT 2.5 Diesel 2WD
Re: Removing Coolant Temperature Sensor
the old fashioned box spanners are good for this job as they are quite long/deep. dont break the plastic end off or make it loose they are easy to crack then the resistance values are altered.
https://www.google.co.uk/search?q=box+s ... 7Q1ZnoM%3A
- Andy + Cath
Great idea, however the set they had in Screwfix still weren't deep enough!  I ended up buying a set of their 1/2 inch drive deep sockets, which were longer than the 3/8 ones I'd already bought, and easily fit over the sensor. Thanks again, sorted eventually!
									A+C
