Bongo has died
- Junior Bongonaut
Bongo has died
We have driven the bongo for a few weeks. I just tried to unlock it with the fob, nothing. So I unlocked it with the key turned the ignition and nothing no lights, no engine turning over absolutely nothing as if it has died. The battery is just 6 months old. Has anyone got any suggestions as to what might be the problem?
Ade
Ade
- haydn callow
Re: Bongo has died
Flat battery
Did you leave something switched on??
Check the voltage across the battery terminals, should be more than 12.6 volts
Recharge the battery and see if it happens again.
- Junior Bongonaut
Re: Bongo has died
Thanks I will try but I'm sure nothing was left on. Will have to try tmrw now but thanks for the tip
Re: Bongo has died
Even with a new battery it could have gone open circuit, complete failure.
Definitely the first place to look.
Re: Bongo has died
Seem to remember there were cases of some stereo's draining power even when supposedly turned off.Do you have a leisure battery or any kind of conversion?
Re: Bongo has died
You're right about stereos.
I think it was mainly the Aldi/Lidl jobbies.
Re: Bongo has died
Those are the one's Bob,just looked back at some of the old posts.Bob wrote:You're right about stereos.
- Junior Bongonaut
Re: Bongo has died
It is the same stereo we have had since day one it is battery as we have not turned over for a while thanks ever so much for replies it us really helpful thanks again all
Ade
Ade
Re: Bongo has died
I had the same issue when I stopped at my parents recently. When I turned the key in the ignition - nothing. I also have a fairly new battery but the problem was that the connections to the battery had become loose. I tightened them up and all was fine.
