Headlight Bulbs
hampshire hog
- Bongonaut
Headlight Bulbs
Can You tell please what bulbs I need to upgrade from the original bulbs,as they don't appear to be strong enough,Thanks.
Re: Headlight Bulbs
They're standard H4s so any legal equivalent will do.
Amazon and flea bay will have loads, or your local car shop.
Re: Headlight Bulbs
Out of interest, do headlights get dim (like me) with age (like me)? Just wondering
Could be me, the bongo or both of us?
Driving at night is like driving with a couple of nightlights in the front. I have put in some ceramic connectors but no change. Or is it because I have just got used to the brilliant headlights on new cars.
Chris with BertieB
- the1andonly
- Tribal Elder
Re: Headlight Bulbs
Another thing to consider is the state of the "glass"
http://www.igmaynard.co.uk/bongo/forum/ ... ng#p647281
Re: Headlight Bulbs
These guys recon bulbs do loose power:
http://www.autoexpress.co.uk/accessorie ... lb-reviews
Reviews too.
Reviews too.
Re: Headlight Bulbs
Its always worthwhile checking the Reflectors....no shiny no light. Also an MOTT failure.
Re: Headlight Bulbs
I sorted this with a pair of 100w spotlights wired up to come on with main beam. Works a treat. I have a fender defender bar to mount them on but people have mounted compact ones in the radiator grille (with suitable cutouts)
Re: Headlight Bulbs
Interesting. "Glass" had good clean a year ago. So maybe I treat Bongo to fresh lights this Christmas.
Chris with BertieB
Re: Headlight Bulbs
Osram Nightbreaker bulbs are a good alternative and not too expensive.
Alan & Dot
Yes sir, I can Bongo !!
Re: Headlight Bulbs
Second that,big improvement!blobber wrote:Osram Nightbreaker bulbs are a good alternative and not too expensive.
Re: Headlight Bulbs
Would these be the ones Alan/Phil?blobber wrote:Osram Nightbreaker bulbs are a good alternative and not too expensive.
http://www.amazon.co.uk/gp/aw/d/B00EPLC ... mdsc?dsc=1
Tempted to treat myself to a pair
- helen&tony
Re: Headlight Bulbs
Yup...they're the ones , Mike...I've got 4 of them
...and a pair of 100 watt spots as per your setup!
Re: Headlight Bulbs
As Helen says,that's them,had mine in over 3 years now,went for them after reading an old thread on here.mikeonb4c wrote:Would these be the ones Alan/Phil?blobber wrote:Osram Nightbreaker bulbs are a good alternative and not too expensive.
Re: Headlight Bulbs
i used night breakers for years, which are very good but these are even better.
http://www.autoexpress.co.uk/car-mainte ... non-ultima.
in the review on these xenon ultima 120% it mentions night breaker plus which are said to be better still, but i have not tested these (plus) ones.
all the above are a crisp white light and not the tinted blue annoying ones, they do make your side lights look yellow in comparison though.
Re: Headlight Bulbs
just found these night breaker unlimited which this review says are better than nigh breaker plus.
http://www.autobulbsdirect.co.uk/H4-OSR ... -pair.html
