Do I need to change my tyres?
Mathter
Post by Mathter » Thu Oct 12, 2006 5:00 pm
Hello again,
My 4wd Bongo has all the same tyres on it - 195/70/15. Should I change the rear tyres to 195/65/15 to avoid any transmission / diff problems or will it be OK to leave tham as they are?
Post by Ian » Thu Oct 12, 2006 5:20 pm
It's OK to have the same tyres on each corner, but not 195s. They are too narrow and will affect your road holding, especially when braking on autumn leaves.
Mathter
Post by Mathter » Thu Oct 12, 2006 6:04 pm
Thanks Ian. I'm a bit surprised by your answer though! Is it just road handling 195s will affect? I say just because the Bongo handles much better in the wet than my Toyota Surf did!
Can you recommend the best size I should go for?
white van man
Post by white van man » Thu Oct 12, 2006 10:10 pm
i presume you mean fit 215,s on the rear!it isnt just the width of the tyre but also the weight/load rating!!!
