Wiring Issue
Spencer54
Wiring Issue
Post by Spencer54 » Fri Nov 13, 2015 12:22 pm
Help me out here.
I have wire running from front to rear to power AV kit, now it was working fine.
All of a sudden its stopped working.
I can get 12v if I use a multimeter but no power to use anything.
Is it possible its corroded somewhere?
Re: Wiring Issue
Post by g8dhe » Fri Nov 13, 2015 12:35 pm
Humm, unlikely to be corroded as such, but where exactly does it terminate in the front to pickup the +12volt supply ? Is there a fuse in the added wire ? What sort of connectors are you using ?
cmm303
Re: Wiring Issue
Post by cmm303 » Fri Nov 13, 2015 3:59 pm
Are you measuring the 12v immediately at the AV equipment supply? In which case does it still read 12v when the AV is switched on?
Chris with BertieB
Re: Wiring Issue
Post by Simon Jones » Fri Nov 13, 2015 6:48 pm
It could be a duff earth connection rather than the live that is the problem. Could also be a fault with the AV kit so try powering it from a different source to eliminate one or the other.
Spencer54
Re: Wiring Issue
Post by Spencer54 » Tue Nov 17, 2015 4:01 pm
This is whats bugging me - earth tests OK, as I run a test lamp and it lights up - but not to that power source.
Interestingly I have a battery test meter connected and it registers as powered but really low.
cmm303
Re: Wiring Issue
Post by cmm303 » Tue Nov 17, 2015 9:54 pm
Spencer54 wrote:This is whats bugging me - earth tests OK, as I run a test lamp and it lights up - but not to that power source.
If you are measuring between the positive of the load (AV or test lamp) and earth then that suggests that either the earth point isn't good (causing its voltage to rise, thus reducing the difference between it and +12v) or the 12v has a high resistance (causing it to drop volts). Eliminate which one by measuring volts between different points along the path from supply to earth.
Chris with BertieB
maxi_77
Re: Wiring Issue
Post by maxi_77 » Sun Nov 22, 2015 6:04 pm
Sounds like some form of poor connection which allows you to see the full voltage but has too high a resistance to carry current. The weirdest form of this I had was a partly blown fuse which really was difficult to find
White diesel Bongo
