In my previous posts, how do I replace the url with text ?.
Thanks in advance.
Ben Bruce.
url links to text
- Muzorewa
Re: url links to text
If you mean the same as I did this one:
While you're at it change the colour to red or blue temporarily too by adding (color=red) and (/color) each end - with square brackets too. You will end up with:
(url=http://www.bsbwebsite.uk/slides_2222/sh ... _2015.html)(color=red] THIS (/url)(/color) and if you use square brackets instead, all you'll see is a red THIS which will go to the linked site when you click it.
there are undoubtedly easier ways but I type (url=) and then paste the link between the = and ) and then type the text I want followed by (/url) at the end - note you have to use the square brackets, I've used the round brackets so it shows up so you can read it otherwise the code is hidden.Muzorewa wrote:That one doesn't work either. Try THIS![]()
