Driver's door window switch
Bestyrich
Post by Bestyrich » Thu Oct 29, 2015 5:09 pm
Afternoon. My driver's door window switch stopped working. I bought a second-hand one but when I fitted it, that didn't work either. I bought a second switch, fitted that, but that doesn't work either. I asked my garage to test it and they said there was nothing wrong with the circuit. But I cannot bring myself to buy a third switch because I have a feeling it is just not the switch that's at fault. It doesn't seem likely that all three switches were duff.
Any thoughts or experience you can share, please?
Richard
Re: Driver's door window switch
Post by mikeonb4c » Thu Oct 29, 2015 6:04 pm
Bestyrich wrote:Afternoon. My driver's door window switch stopped working. I bought a second-hand one but when I fitted it, that didn't work either. I bought a second switch, fitted that, but that doesn't work either. I asked my garage to test it and they said there was nothing wrong with the circuit. But I cannot bring myself to buy a third switch because I have a feeling it is just not the switch that's at fault. It doesn't seem likely that all three switches were duff.
Richard
Are you 100% confident the garage know how to test auto electrics, otherwise suspicion has I think to move to the wiring (harness) on the drivers door. It is quite common for wires to fracture inside the harness due to repeated flexing over the years, usually near the grommet where the harness disappears into the car bodywork.
Post by Bob » Thu Oct 29, 2015 6:31 pm
There is a little On/Off switch below, and at 90 degrees to, the two window switches, make sure its on, otherwise likely what Mike suggests.
Where are you? Someone might take a look for you.
Jaws
Post by Jaws » Sat Oct 31, 2015 2:07 pm
Richard
As you say, unlikely all switches were duff. Almost certainly a break in the wiring where it passes between the door and body just above the lower hinge. (As suggested).
Unwrap the bundle as needed to examine each conductor and I bet you will find a break, usually at the lowest point of the curve between frame and door.
Live Bongo and prosper.
