Cooling - just checking
cushers
Post by cushers » Sun Oct 04, 2015 4:18 pm
Hi All again.
Just had ALL coolant pipes (metal and rubber) replaced along with new rad, water pump and thermostat. Left lots of paper work with garage and they said that the paper work helped and they followed the instructions for the bleed (I trust him).
Picked Freda up today and have given her a good, but tentative work out. What I found is that the temp gauge sits a little higher than it did previously (now just below 12 o'clock as opposed to 11 clock) the heater gets warm, the bottom hose on the rad gets warm and the rad fans kick in. Towards the end of my short journey home I turned at a junction (hard left). The gauge went to about 1 o'clock and then dropped very quickly.
Does this sound ok?
95 2.5 TD Freda
Graeme
Re: Cooling - just checking
Post by rita » Sun Oct 04, 2015 5:15 pm
Its very hard to say exactly (after the parts mentioned have been fitted )what the gauge (if it is the standard DOCTORED gauge ) should read. Personally I would have the system rechecked and bled and if possible use the vacuum system.
cushers
Post by cushers » Sun Oct 04, 2015 7:23 pm
That seems sensible. Hope it was just a "burp" as after everything had cooled down I checked the expansion tank and underneath the filler cap was empty. Fingers crossed its not in the engine / head.
Graeme
Post by rita » Sun Oct 04, 2015 7:33 pm
cushers wrote:That seems sensible. Hope it was just a "burp" as after everything had cooled down I checked the expansion tank and underneath the filler cap was empty. Fingers crossed its not in the engine / head.
Graeme
That's exactly what you wanted is a BURP, it probably means that the system was not completely cleared of Air.
Post by Bob » Sun Oct 04, 2015 7:41 pm
If the coolant has dropped below the bottom of the header tank don't drive it until it has been bled agin, there will be air in the system and it will overheat.
Post by haydn callow » Sun Oct 04, 2015 7:58 pm
Sounds as though they didn't bleed it fully....beware!!
cushers
Post by cushers » Sun Oct 04, 2015 8:23 pm
Thank you for your replies.
Fingers crossed it was a burp then. Like i say, 10 minutes earlier (while I was engine running but stationary in the garage forecourt doing the tires) the bottom hose got hot as did the bottom of the new rad and heaters.
Unfortunately I am parked up 1/4 of a mile from where I can tinker. Would a 3 min drive be a massive risk?
G
Post by Bob » Mon Oct 05, 2015 8:13 am
Its really difficult for someone else to say this short drive would be OK just incase something goes wrong and they get blamed.
Could someone give you a tow for that short distance?
All wheels on the ground if its 4WD and max 20mph if auto.
Good luck.
Post by mikeonb4c » Mon Oct 05, 2015 8:40 am
I find it really hard to believe a 3 minute drive could do Amy harm but like Bob I'd be nervous of guaranteeing it. Any more experienced techies able to advise on here?
Post by Northern Bongolow » Mon Oct 05, 2015 8:28 pm
or you could spin that round mike, why drive it and risk damage when its an easy job to tow it, or do a basic bleed and fill without the engine running. :wink:
Post by mikeonb4c » Mon Oct 05, 2015 11:58 pm
Northern Bongolow wrote:or you could spin that round mike, why drive it and risk damage when its an easy job to tow it, or do a basic bleed and fill without the engine running. :wink:
True, but not an easy job if like me you don't have a handy friend with car and tow rope. My question really is whether 3 minutes of running an engine from cold could ever come close to causing a head cracking hot spot. Maybe it could, but it seems unlikely to me. And towing a 4wd automatic carries its own risk if not done right?
roosmith
Post by roosmith » Tue Oct 06, 2015 8:23 am
I'm confused. I know we all have this phobia about the cooling systems in our Bongo's however the engine can't overheat in 3 minutes. In 3 minutes, my hot running Bongo probably wouldn't have reached 35. That is a way off the 100+ which might damage a head.
Post by rita » Tue Oct 06, 2015 8:49 am
Driving the vehicle for 3 minutes providing that the engine has coolant and you are not driving up Ben Nevis should not present a problem.
The BURP that occurred was probably the last stage of the bleeding process and I would not be surprise if every thing is OK now.
Good Luck.
cushers
Post by cushers » Tue Oct 06, 2015 9:01 pm
You guys are great. At least I know now that the conversations that I have with myself are sane! Obviously any decisions I make are down to me and I appreciate the warnings. That's what makes this forum great, open, honest opinion.
Will research the cold bleed more fully. Can't believe I missed it.
Graeme
cushers
Post by cushers » Sat Oct 17, 2015 10:40 am
Just an update.
Before the bleed I removed the de-gassing tank (simple job) and gave it a right old clean. Just washing through first and then shaking vigorously. Glad all that crust isn't sitting in the system now and I can see the fluid level in the partition under the pressure cap. While it was out I fitted the Haydn LCA sensor. I bought the "piggy simples" version and had the LCA fitted in no time. Highly recommend Jo and Haydn.
Plumbed everything back together and did a bleed as per videos and advice.
Things seem good. During the bleed I got a "burp" which I assume is the thermostat opening (bottom rad hoses got v hot). After that there just seemed to be very fine "cavitation" bubbles. I guess these come from the water pump and lack of system pressure while bleeding. . Didn't experience any gassing in to the system while doing higher revs.
A question though?
Will higher revs force water up and out of the degassing tank while the cap is off (hope that's the reason)? Did it all on my own and held the funnel in place when necessary by attaching it to the passenger door seatbelt tang using some coat hanger (I was able to remove it quickly when needed)
Thanks for all the help and advice
Graeme
