ODBC/ ODBC2 interface socket on Bongo?
Purple Pixie
Post by Purple Pixie » Sat Sep 05, 2015 10:53 am
Having just successfully connected a £8 bluetooth ODBC interface to my Honda Jazz to output coolant temperature, throttle position, fuel flow etc etc as a live display on my phone/tablet, I return to the prospect of tapping into the Bongo
http://www.ebay.com/itm/321796135993?it ... m=&vxp=mtr
Excuse me for any repetition BUT where is the ODBC1/ ODBC2/ ODBC x.x??? plug?
I seem to recall the Bongo was not set up for interrogation using anything other than your ears and eyes but I am an iquisitive cove at the best of times and would like to explore all avenues especially any feed of AFR or lambda...
I have a stand alone Bosch-based AFR/Lambda monitor that can output a voltage to spoof the narrow-band lambda sensor on the bongo, if the narrow band is not working I can identify this if the AFR is restored when the spoofed feed is used [I just need to get a second lambda sensor mounting collar TIG'd into cat bypass pipe
RELATED SUBJECT: anyone know what the oversize crush down exhaust gasket is called (part no??) it is approximately the same size as the firering gasket between the exhaust manifold and the downpipe???
Cheers!
1999 Ford Freda - "Purple Pixie"
Re: ODBC/ ODBC2 interface socket on Bongo?
Post by g8dhe » Sat Sep 05, 2015 10:57 am
Under the glove box in the passenger footwell.
Purple Pixie
Post by Purple Pixie » Sat Sep 05, 2015 11:12 am
OK, I will see what flavour of ODBC it is (passive mode)
JoeC
Post by JoeC » Sat Sep 05, 2015 12:32 pm
g8dhe wrote:Under the glove box in the passenger footwell.
I see you have a shakey-shakey tourch.
Purple Pixie
Post by Purple Pixie » Sat Sep 05, 2015 12:35 pm
it is a weird one, it is NOT the same socket as my Honda.....need a pinout to convert it to ODB, hopefully (the one in my hand)
https://drive.google.com/file/d/0Bxxkc_ ... sp=sharing for what it looks like
Purple Pixie
Post by Purple Pixie » Sat Sep 05, 2015 1:09 pm
https://www.academia.edu/15415565/Fault ... _ODB2_not_
is the end of it really, nothing to view in realtime sadly!
NB the torch is in the place your flare should be, highly illegal I guess to carry them in the UK but quite a show-stopper if you are accosted by a road rager who has his window open!
Post by Simon Jones » Sat Sep 05, 2015 1:10 pm
It's a Ford/Mazda-specific connector and protocol so is not ODB/OBD2 compliant. Very few people have managed to get anything meaningful out of it. Let us know if you have any more luck.
Try this for starters: http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm
Rapidair65
Post by Rapidair65 » Mon Sep 07, 2015 10:44 pm
Please let me know if you have any success. I have been trying to trouble shoot a fault in the engine management system on my 2004 2 litre for some time. It is very frustrating that Mazda fit a diagnostic plug that's about as much use as a chocolate teapot! I now face the prospect of replacing the engine sensors one by one until the check engine light stays off. With a lambda sensor at £229, this could get very expensive.
1998 green and silver V6 called 'Blossom'
2004 white 2 litre tin top called Buzz.
Purple Pixie
Post by Purple Pixie » Mon Sep 07, 2015 10:52 pm
check the lambda operation over the length of a journey with a recording software/usb oscilloscope, you can get the fault codes out by using a wire jumper in the socket and an LED, the operation of a lot of other gubbins can be monitored if you have a pet electronics engineer nearby! (Thanks Nick)
Post by Simon Jones » Tue Sep 08, 2015 7:47 am
Replacement universal lambda sensor can be picked up for under £50: http://igmaynard.co.uk/bongo/forum/view ... 15#p646268
John, that link doesn't seem to bring up anything. Do we need to register to be able to log in? I'm interested to find out more about the diagnostic socket as I'm planning to build a small switch box with LEDs to allow the various pin configs to be connected up. I'm not keen on the idea of shorting out pins on the socket with a paperclip as its bound to end in a puff of smoke and some expensive damage :?. Thanks.
Purple Pixie
Post by Purple Pixie » Tue Sep 08, 2015 7:51 am
yes you do but here it is on my google drive:
JB
helen&tony
Post by helen&tony » Tue Sep 08, 2015 8:53 am
Simon...
Would it not be easier to buy a Japanese reader?...I'm not sure if anyone has tried, but there must be one available, perhaps it was used in conjunction with Ford?....If there's a reader, perhaps it could be copied , somehow, if it's no longer in use.
Post by Simon Jones » Tue Sep 08, 2015 8:56 am
Thanks. That looks to be the same stuff from my previous link. I was hoping you'd stumbled on the holy grail of Mazda diagnostics :).
Helen, there is the proper Mazda code reader referred to in the engine manual which I'm keeping my eyes open for. Other folk have had some success with a generic ELM327 reader linked to Ford's ForTran software.
Purple Pixie
Post by Purple Pixie » Tue Sep 08, 2015 11:05 am
Simon Jones wrote:......,there is the proper Mazda code reader referred to in the engine manual....
do you have a part number for this????
Simon Jones wrote: a generic ELM327 reader linked to Ford's ForTran software......
Any more info on this since the reader will need a wiring adaptor to fit in the Bongo plug.....
Post by Simon Jones » Tue Sep 08, 2015 11:22 am
Looks like its called ForScan rather than ForTran (which is old-school programming language). Link here with some other useful info: http://www.igmaynard.co.uk/bongo/forum/ ... 4&p=609029
