Sink tap ,cool box not working
smully
Post by smully » Mon Aug 24, 2015 9:03 pm
Evening all.
I've a rear conversion in my bongo.
the other day, both the cool box and tap stopped working.
I'm presuming it's a fuse issue but I've checked everything by the drivers knee fuse box and they're all fine.
It's a basic rear conversion with a 240v hook up but without a leisure battery.
Any ideas where to start looking.
Re: Sink tap ,cool box not working
Post by g8dhe » Mon Aug 24, 2015 10:18 pm
Most conversions will have there own feed and fusing arrangements unconnected with the vehicle fusebox.
Are you sure the 12 volt feed is from the Starter Battery ? If it is then look for its own fuse direct from the battery itself.
smully
Post by smully » Wed Aug 26, 2015 12:11 pm
Sorted it.
Just the fuse in the 12v hook up lead running from the rear auxiliary socket.
Cheers for the advise.
