Rear fog light (V6)
waverider1
Rear fog light (V6)
Post by waverider1 » Tue Aug 11, 2015 3:23 pm
Any ideas on what bulb number/ wattage/ size / bayonet or wedge fitting, is needed to replace/ convert a rear clear reverse light bulb into a legal red fog light in the rear drivers side cluster (on a new shape 2002 V6 Aero Bongo - so red tape doesn't have to be stuck over it on the outside!). Any advice would be helpful. thanks.
Re: Rear fog light (V6)
Post by g8dhe » Tue Aug 11, 2015 3:46 pm
Post by Simon Jones » Tue Aug 11, 2015 4:09 pm
This is from my '02 and you can see the convertor just dipped the bulb in some kind of red lacquer & so far, it's been fine. I believe it is some kind of wedge bulb rather than bayonet:
windywatson
Post by windywatson » Thu Aug 13, 2015 9:50 pm
Fog light bulbs are 21w so that they are bright enough to be more visible through fog. Importer wanted to do the same as your intending to do on my 2001, but I wasn't convinced that the reversing light cluster would actually give the correct type of light dispersal. So fitted traditional style after market fog as wanted to make sure if used in foggy condition it was going to do the job.
Windy-Watson
2001 V6 Tin Top
waverider1
Post by waverider1 » Mon Aug 17, 2015 4:59 pm
Hi, thanks for all your swift help and answers to the fog light bulb solution!
After a bit more research, I think the original clear reversing bulb is possibly a 12V 18W 10mm wedge fitting type in the new shape bongos, like Simon pictured. However, I can't seem to find any red bulbs anywhere that would fit this spec, apart from a 20W 9mm wedge capless bulb which I guess may fit & do the job if it doesn't blow the fuse as it's 2w more? So, I guess my options are; try the bulb (see if fuse blows); paint the current clear reverse bulb with Shellac glass paint (worried about flaking); put up with the red tape (looks naff?); or put a new dedicated fog light in as suggested (but this would mean re-wiring)?! mmm... decisions!
Post by Simon Jones » Mon Aug 17, 2015 5:39 pm
I think you'll be fine with a 21W bulb as it draws 1.75A as opposed to 1.5A for 18W. I imagine the fuse will be at least 5A so there's plenty spare. If you do find a suitable red one, please post details on the forum as I'll get one as a spare. Thx
