Handbrake warning light
rocketeeer
Post by rocketeeer » Sun Aug 02, 2015 8:35 pm
My handbrake warning light stays on most of the time when I'm driving, though the handbrake is definitely off.
Does this signify anything?
Rocketeeer
Re: Handbrake warning light
Post by g8dhe » Sun Aug 02, 2015 8:38 pm
Yes your brake fluid level is LOW !
Even if it looks ok when you look at under the bonnet on level ground you will find that as soon as you hit a slope it will start warning you. Fill it up ASAP. The tank is centre left at the rear under the bonnet.
JoeC
Post by JoeC » Sun Aug 02, 2015 9:17 pm
or there is something wrong with the switch under the centre console where the base of the handbrake is.
Post by teenmal » Mon Aug 03, 2015 11:15 am
If the fluid level and the handbrake switch is ok check the servo vacuum switch.
