Hi all,
A couple of normal issues to sort, 2 new front brake discs and a rear and middle exhaust pieces, but I also need a new rear prop shaft and an inner drive shaft seal, there was oil everywhere underneath, I think it's the N/S/F diff?
Does anyone have any recommendations on where best to get the seal and rear prop shaft?
My baby is a 97 2.5D 4WD
Kind Regards,
Bongo been in for a health check :(
1997 Mazda 2.5TD 4WD AFT (Current) - The Red Slipper!
1995 Mazda 2.5TD 2WD AFT (2007- 2014 RIP)
Re: Bongo been in for a health check :(
on top of the diffs both back and front, and the transfer box, is a little thimble type breather, when the oil gets hot it expands, if this is blocked like most are the increase in pressure blows a seal where ever it can, usually freeing up the breather is enough and the seal is good again, worth a try as its cheap.
the thimble filter should screw round and lift slightly, most are rusted shut or painted or undersealed closed.
