Connecting up Front Fog Lights
Posted: Fri Jul 17, 2015 10:57 pm
Hi, everyone.
I've acquired a pair of secondhand Bongo front fog lamps, followed the various posts on here to locate the wiring connections. I think I've found them, there were a group of relays behind the leisure battery and this blue plug was coiled and taped up at the side. Does this look right (link to pics below)?
https://goo.gl/photos/TFSZrJ9sog8TrXXFA
So, assuming that's the correct plug I need to work out how to wire them up - unfortunately I don't have the last part of the wiring that connects to the lights. I can see some of the wiring colours are similar from the section of wire left on one fog light, but not sure how they all connect up - any suggestions?
After that, I assume it's a case of popping a fuse in the empty slot in the fusebox and trying to locate the wiring coming into the dashboard for my fog light switch ...
Thanks,
Andrew
Thanks,
Andrew
