Connecting up Front Fog Lights
andrewlyon
Post by andrewlyon » Fri Jul 17, 2015 10:57 pm
Hi, everyone.
I've acquired a pair of secondhand Bongo front fog lamps, followed the various posts on here to locate the wiring connections. I think I've found them, there were a group of relays behind the leisure battery and this blue plug was coiled and taped up at the side. Does this look right (link to pics below)?
https://goo.gl/photos/TFSZrJ9sog8TrXXFA
So, assuming that's the correct plug I need to work out how to wire them up - unfortunately I don't have the last part of the wiring that connects to the lights. I can see some of the wiring colours are similar from the section of wire left on one fog light, but not sure how they all connect up - any suggestions?
After that, I assume it's a case of popping a fuse in the empty slot in the fusebox and trying to locate the wiring coming into the dashboard for my fog light switch ...
Thanks,
Andrew
Re: Connecting up Front Fog Lights
Post by g8dhe » Sat Jul 18, 2015 11:53 am
andrewlyon
Post by andrewlyon » Sat Jul 18, 2015 8:36 pm
Thanks, my VIN is in the manual that isn't available, but looking at the earlier series manual:
http://www.g8dhe.net/bwm/bwmanualp.htm?1999/Page_68
so I reckon that the plug I found is E2-02, the correct feed for the front fog lights, leading to the E2-03 and E2-04 connectors on the fog lamps themselves. I'll have to make my own connections but at least I'm on the right track!
Thanks for your help,
Andrew
Post by Simon Jones » Sat Jul 18, 2015 10:14 pm
Looking at the connector and it's location, I would say that should plug into the bottom of a relay (which may well be for the front fogs). I've got a spare relay or two if you need one in exchange for a beer token ;).
