I'll post what I know - can anyone fill in the gaps? I can go and look for more details if anyone can tell me what to look for!
I have quite a large starter battery.
I have what I think is an 85Ah Leisure battery on the opposite side under the bonnet. (battery link)
I have a mains hookup system which has a little fuse box and a double mains outlet. It also powers a battery charger.
The charger is a Supercharge 151 (charger link)
With the ignition off the only things that work are the lights and the 12v socket in the kitchen unit (which powers the coolbox)
I am presuming that the lights are running off the SB though?
The LB doesn't appear to have much wired up to it at all. Physically it has one medium thickness wire going from the neg terminal to a grounding bolt just behind the battery. It then has a pair of wires with one going to each terminal (pretty sure this is the mains powered charger).
Other than that it just has 2 more red wires going from the pos terminal. They go a short distance to a fuse holder (one yellow fuse and one green fuse). From the fuse holder - they go off as a pair of wires under the air intake thing and I guess over towards the SB.
The SB itself has a black wire coming from the pos terminal with an inline fuse shortly after (I think this is the coolant alarm?) It has a black fuse box just behind the battery. I can also see a clear looking box with relays or fuses in behind this tucked in on the inner wing.
Other than that I found a relay which doesn't look too original which is mounted to the left of the air intake. It says NAGARES RLP/4-12 12V-40A.
So what else do I need to find to work out what is going on with the split charge system?
