Oil Filler
Alfredo Garcia
Oil Filler
Post by Alfredo Garcia » Sun Jul 12, 2015 7:10 pm
Hi all
I just bought my first Ford Freda its a 4wd AFT 2.5 diesel
Now I know theres questions been asked such as where is the oil filler etc and people have looked under the bonnet or drivers side without looking under the passengers side so I wont be a space cadet ........until I can't find where to put the oil.
Looked under passenger seat, found bright yellow dipstick handle but where to put oil in? Seen answers to other queries and filler is just above dipstick but mine seems to have blanking plate with filler cap on top of engine under the metal centrepiece where gear change is. This can't be right?
I have photos but dont know how to post??
Alec
Re: Oil Filler
Post by Northern Bongolow » Sun Jul 12, 2015 7:30 pm
does it look like this pic, its of a mazda b2500 pick up engine.
http://www.idealengines.co.uk/images/ca ... 00_eng.jpg
Alfredo Garcia
Re: Oil Filler
Post by Alfredo Garcia » Sun Jul 12, 2015 7:44 pm
Yes I think so. obviously harder to see with all the panelling around
Re: Oil Filler
Post by Simon Jones » Sun Jul 12, 2015 8:03 pm
This is the Ford Ranger version of the WLT engine and it has a filler cap on the rocker cover and a blanking plate where the pipe and cap would be on a Bongo engine. If yours does look like this, then it suggests the engine or head has been swapped (not particularly well) from a Ranger. I've got the bits you need if you want to convert it back to how it should be.
Re: Oil Filler
Post by Northern Bongolow » Sun Jul 12, 2015 8:09 pm
if it is either the same as mine or simons check the exhaust manifold, the egr pipe connection is slightly different to the bongo. the bongo egr pipe should screw into the rear of the manifold but the b2500 bolts onto a block at the rear of the manifold, not really a problem to look at it, but it eventually melts the large black plastic air pipe that goes round the rear of the head.
Alfredo Garcia
Re: Oil Filler
Post by Alfredo Garcia » Mon Jul 13, 2015 7:11 am
Thanks. On that note the exhaust has just sheared at the end of long front section where it bolts to 2nd section. I took to Kwikfit (at just up the road) and they have ordered a part. Will this still fit ok with the egr issue you mention? Is this just a case of it plugging in?
Sorry but new to this and not had Freda/Bongo before.
Re: Oil Filler
Post by Northern Bongolow » Mon Jul 13, 2015 7:01 pm
yes the exhaust you ordered will be ok.
Alfredo Garcia
Re: Oil Filler
Post by Alfredo Garcia » Mon Jul 13, 2015 7:43 pm
Thanks for the help hopefully be back on the road tomorrow.
Is this different head thing a common change? Also can I just change blanking plate for filler neck otherwise gonna be hard to top up oil?
