tyre sizes
BongoBeeman
tyre sizes
Post by BongoBeeman » Sat Jun 20, 2015 10:37 pm
Our bongo came with loads of japanese papers (interesting but can't read lol) but also an english translation of the manual. I was reading it and saw tyre pressures for 195s at the front and 215s at the back. So went to check on the bongo and mine has 215s at the front and 195s at the back. I think the numbers are correct off the top of my head but anyway I have larger at front and smaller at back)
What do others have, I'm thinking I should be changing them round
scanner
Re: tyre sizes
Post by scanner » Sat Jun 20, 2015 10:57 pm
Yes - sooner, before you are later.
That is the wrong way round and you could end up the wrong way round.
blobber
Re: tyre sizes
Post by blobber » Sat Jun 20, 2015 10:58 pm
Definitely the wrong way round. 195's should be on the front. Swap them asap otherwise stability and handling will be compromised.
A lot of people, me included, opt for 215's all round, might be worth considering.
Damn, scanner beat me to it!!!
Alan & Dot
Yes sir, I can Bongo !!
BongoBeeman
Re: tyre sizes
Post by BongoBeeman » Sat Jun 20, 2015 11:07 pm
Thanks, will do :)
Gasy
Re: tyre sizes
Post by Gasy » Sun Jun 21, 2015 8:09 pm
Or just go every where in reverse
BongoBeeman
Re: tyre sizes
Post by BongoBeeman » Sun Jun 21, 2015 10:13 pm
Gasy wrote:Or just go every where in reverse
Like it :) and the aerodynamics are abput the same!
Re: tyre sizes
Post by Bob » Sun Jun 21, 2015 10:18 pm
Probably better due to Induced Votex.
