Aircon ... is it front only or dual?
TonyW
Post by TonyW » Fri Jun 19, 2015 11:11 am
Hi all,
Probably a stupid question but .....
I have an original (un-modernised) 1995 2WD Bongo ..... just about to get the aircon serviced.
In the very helpful factsheet in the members are it says; "Re-gas system using R134a. The system will take approximately 950g (for dual system) or 700g (front system only)."
So, mine has a front and rear blower panel with a switch on the dash to turn on/off the rear set ... but is the aircon separate or is it "dual"?
It obviously makes a difference to the amount of gas which needs to be replaced.
Apologies if this has been asked elsewhere.
Thanks for any help.
Tony.
Re: Aircon ... is it front only or dual?
Post by g8dhe » Fri Jun 19, 2015 11:38 am
As standard its always "dual" but in some conversions or following leaks some people have bypassed the rear system to make it front only. You would have to check the piping underneath to see if the rear has been bypassed.
TonyW
Post by TonyW » Fri Jun 19, 2015 12:01 pm
Thanks Geoff!
mantaJim
Post by mantaJim » Sun Jul 26, 2015 11:59 am
For the first time in 4 years of Bongo ownership I've finally got round to seriously considering having my aircon checked out and re-gassed. It has a JAL rear conversion so no rear heater controls etc. I bypassed the rear heater matrix following a leak at the matrix last year but have never touched any AC pipework. Might be a stupid question as I know nowt about aircon but would I need to regas on the basis of front or dual and do I need to do anything with any aircon pipes ?
I've also been trying to find info on hear on how to check the AC compressor is working - I recall something about shorting or bypassing connections but can't find the thread.
Jim
V6 Mushroom
Post by Simon Jones » Sun Jul 26, 2015 1:24 pm
Unless the A/C has been blanked at the rear (v. unlikely) then it will need to be regassed on the basis of being dual system. I've blanked mine and the place I went to for regas has the info on his database about correct capacity for single and dual systems. If the A/C doesn't work, be wary of bypassing the pressure sensor on the dryer unit as the pump is easily ruined if run without lubrication.
mantaJim
Post by mantaJim » Sun Jul 26, 2015 6:36 pm
Thanks Simon
I'll bear that in mind.
All the best
Jim
V6 Mushroom
Post by teenmal » Mon Jul 27, 2015 12:45 pm
Apparently the Rear air con is an Optional Extra.
PRODUCTION OPTIONAL EQUIPMENT
Air condition / Dual air condition
Central locking
Electric windows
Steering wheel tilt
Drop down type rear seat
Split 60/40 rear seat.
Rear 3 point seat belt
Side impact bar
Airbag - Driver
Airbag - Passenger
AM/FM radio equipped cassette player.
Sunroof / Moonroof
Front fog lamp
Front spoiler
Rear wiper
Rear or roof spoiler
ABS (Antilock brake system)
Privacy glass / UV glass
wonkanoby
Post by wonkanoby » Mon Jul 27, 2015 2:39 pm
never heard of one did not have dual a/c myself
Post by teenmal » Mon Jul 27, 2015 3:07 pm
wonkanoby wrote:never heard of one did not have dual a/c myself
That probably because the original purchaser of the vehicles opted pay to have them fitted.
Post by Simon Jones » Mon Jul 27, 2015 9:05 pm
The whole rear heater unit was an option, but seems to have been fitted across the overwhelming majority of vehicles.
Another pretty much 'standard' option is the power folding mirrors but there are still one or two vans knocking around without the extra switch and motors.
